Home > Technical (L322) > Various dash items no longer function?
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Well, the electronic Gremlin finally has made an appearance on our L322 Rolling Eyes
The fuel gauge doesn't go all the way to full (about 80% when filled to the brim) , the parking sensor system sometimes works, then not, gives a faulty sensor reading, The dash info centre under the speedo works fine but the button on the indicator stalk doesn't let you pick a different value in the info thing. It does, but it doesn't stay on that value (for instance average fuel consumption.
Would that be through a bad earth somewhere maybe ?
I erased a fault with the GAP tool (forgot what it was) but the problems come straight back.
Post #689759 2nd Apr 2024 5:02pm
Gremlin500
………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #689788 2nd Apr 2024 11:35pm
Dutchgit
Cheers, I'll have a look once the sun makes an appearance Rolling Eyes
Post #689789 3rd Apr 2024 12:02am
Dutchgit
Haven't had time to research the inconvenience in the dash yet but did a quick look-see with the GAP again to make a screenshot of the fault code.
Any one had this and found the problem perchance ?
Thanks in advance.
Cheers, Ard
Post #690017 5th Apr 2024 7:23pm
