Home > Technical (L322) > Where's the Mic for the Handsfree?
Andy S
OK, someone out there is going to know the answer I'm sure!
On my FFRR (2010 MY Vogue SE) I have the standard bluetooth handsfree kit, I'm guessing the same kit which I had in my previous RR Sports and Freelander 2. Now in all the other cars, nobody ever said 'you sound a long way away' or 'you're very muffled' when I used the phone. In the FF though, its a constant refrain. So I'm guessing there's a load of dust/debris blocking the mic, but I have no clue where it is - no hint in the handbook. So over to the epxert panel!
Post #248650 16th Mar 2014 7:00pm
The grille next to your sunroof switch sir Thumbs Up
Post #248653 16th Mar 2014 7:20pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Put a new microphone in mine as everyone I spoke to said it sounded like I was under water and they could not hear me. New mic, no problem (annoying as did work until 3 or 4 weeks ago)
Can confirm mic is behind the centre grill on the front over head console. It can be fitted for RHD or LHD. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #248676 16th Mar 2014 10:13pm
Andy
There is an upgraded mic available from bmw. It's cheaper than the original too.
Post #248711 17th Mar 2014 6:41am
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Have you got a link? Are the easy to fit
Post #248717 17th Mar 2014 8:50am
rej
It took me about 2 mins to fit. Remove the black grill to the right of the overhead console, push out the centre grill, disconnect mic, remove mic from housing, clip in new mic, connect plug, push back the 2 grills and done.
Took longer to type that to do. There is a difference between knowing your sh!t and knowing you're sh!t
Post #248724 17th Mar 2014 10:04am
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
I'd like to upgrade the mic on a 2012 Supercharged. What's the part number? Any other directions/thoughts appreciated. 2012 Supercharged L322
Post #689954 4th Apr 2024 10:53pm
dhallworth
Nobody can understand a word I’m saying in my car either so I’d like to change the microphone in mine as well.
Looking online, it appears that the Land Rover part number is XVC000050. It retails at £46.40.
If anybody knows the BMW part number I’d appreciate it if it’s genuinely an upgraded part. Otherwise I’ll order the genuine one.
Edit - Just realised that this thread is 10 years old! Laughing I’m going to order the genuine one tomorrow.
Thanks,
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #689956 4th Apr 2024 11:40pm
TorontoDee
Anyone know if the plug is the same between LR038176 and XVC000050.
Smile 2012 Supercharged L322
Post #689964 5th Apr 2024 2:10am
dhallworth
Doesn't look like it.
XVC000050
LR038176
Post #689987 5th Apr 2024 12:42pm
Iwheels
Canada
Is there any way to upgrade the XVC000050?
or are we all stuck with it? The quality is sooo bad!
can the plug be exchanged?
Post #690031 5th Apr 2024 11:53pm
dhallworth
Is it that bad or do you just have a bad microphone?
We’ve got a 2012 with 26k miles on it and it’s perfect. We’ve got a 2012 with 100k on it and it’s crap.
I’m collecting my new microphone tomorrow as I don’t believe there’s anything wrong with a properly working original one. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #690032 5th Apr 2024 11:56pm
David, why don't you swap the microphones and see if the problem moves vehicle? Im sure dad won't mind Whistle Thumbs Up
Post #690033 6th Apr 2024 12:58am
dhallworth
I did wonder about that but didn’t want to risk damaging anything in his car so I ordered a new one yesterday to collect this morning.
I then had a poke about in my car and saw just how easily it comes out so it would’ve been very easy to swap them. Laughing
Oh well, good job it’s not a lot of money! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #690049 6th Apr 2024 9:17am
TorontoDee
I've ordered a replacement. Told to expect a call Wednesday to head over and pick up at the Parts counter. 2012 Supercharged L322
Post #690104 6th Apr 2024 5:31pm
