Home > Technical (L322) > Slipping in gears and trans fail safe mode |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
First thing I would do is check oil level followed by changing oil & filter……easiest & cheapest on your list.😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
14th Jan 2024 9:47am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
It’ll be a blocked and / or leaking trans cooler. It’s a known issue with older L322’s, not a big job to replace and while you’re at it you would be advised to swap out the gearbox filter and fluid as well..good luck ______________________________
14th Jan 2024 10:28am |
L322Brothers Member Since: 13 Jan 2024 Location: Gelderland Posts: 5 |
Thanks a lot for the advices. Will definitely change the oil and will have a look at the trans cooler.
14th Jan 2024 6:13pm |
Hi,
14th Jan 2024 7:48pm |
bradww Member Since: 24 May 2023 Location: Chesterfield Posts: 35 |
Do you get the 'RESTRICTED PERFORMANCE' Warning? Does it clear once the box has cooled down (via less frequent changes?). |
15th Jan 2024 9:01am |
Their Range Rover is a 2003 model so the warning they get is ‘ Trans fail safe mode ‘ and reading between the lines it clears once it has cooled down. ______________________________
15th Jan 2024 10:11am |
I ask as I'm encountering an occasional RESTRICTED PERFORMANCE (MY2010) that seems to clear itself. No codes logged though
15th Jan 2024 12:57pm |
It could be blocked and have restricted flow. I don’t have any experience of the newer L322 but I think it wouldn’t be too different, may be worth a look to cross it off the list of possibilities. ______________________________
15th Jan 2024 1:26pm |
I only receive the trans fail safe mode message. And this message doesn’t always pop up.
15th Jan 2024 7:00pm |
Sooo, we put a ‘new’ gearbox in the car. It shifts very smooth now. But we’ve got a new problem back. When driving at 60-70km/h the engine rpm goes up and down with 50rpm and it feels like you’re driving over the white road markers. A bit bumpy. When accelerating is goes away and its smooth again. There is also a noise thats sounds like wind noise coming from under the car.
14th Apr 2024 4:07pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Possibly torque converter. Did that not get changed out when box replaced? Previous cars:
14th Apr 2024 4:15pm |
The torque converter was changed with the ‘new’ box. We’re told that the torque converter and box were all fine. Is something like Dr. Tranny a thing that can work and fix it? |
15th Apr 2024 1:37pm |
