Home > Technical (L322) > Removing scrivets from the A-pillar (both sides) |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
You have to drill them out and buy new ones. This is the case when your windscreen is replaced. Ring the part department and ask for an a pillar cover fixing kit. You should get replacement plastic rivets and the plastic inserts for the holes in the body shell.
13th Aug 2011 10:52pm |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 |
You can drill them out, you can drill a pilot hole and thread a fine screw and pull them out or ... as I do, with a punch, just knock the centre through (the centre just falls to the bottom of the A-Pillar) and they then just pull off! |
15th Aug 2011 9:02am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Ahhh, a quality stickler. I know how that is. Nearly everyone else I've ever dealt with just punches them through.
16th Aug 2011 1:07pm |
