![]() | Home > Technical (L322) > Drop links - Anti Roll Bar links - suspension knocking noise |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Just realised this should really be in the maintenance section if someone can move it for me.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Good work Adam
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 375 ![]() ![]() ![]() |
Adam
Normally when the front drop links go weak, you have a rattling sound coming front the front wheel. It appears worse when you travel over uneven ground. Best to replace both left and right at the same time. I was changing them on my X5 every 20k. |
Noise was from front n/s and also appeared rear n/s but noise has stopped now. I replaced both left and right front drop links, as I said cheap and really easy do both.
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
were did you get them from ? |
I got mine from eBay, just search for L322 Link They are one of those things where the pattern part is better quality than original. I only needed to do the front on mine, I paid a garage 1/2 hour labour to change them. ![]() |
ill have a look thanks dan
I got them from LRparts, there was 3 options, Genuine LR, Replica ones made by same company that provide LR, then there was replica ones from britparts.
I believe so. ![]() |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
I've just changed my front airbag/strut on the passenger side and had a knocking noise coming from that side ever since! Whats this hard washer? Have you got any pics or a link to this hard washer? Just a thought but I don't remember it when putting my drop links back on ![]() ![]() ![]() |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
According to Rave the hard washer goes in the top fitting behind the balljoint where it fits into the damper. Not on the side where the nut is. If you download Rave you can read about it for yourself and see the pictures. |
