Home > Maintenance & Mods (L322) > 'SUSPENSION LOWERED' Error Message
PJS
So when i started the car up earlier, this message came up:
And also 2 lights on the height control section:
Happened a few times in the week, but when i turned off the car and started it back up it didnt appear. Today i turned the car on and off 3 times and still showed it (disappears after 30 seconds or so)
Twisting the height adjuster doesnt do anything (not sure if it even works when this fault doesnt show - will test it)
Any idea what the problem is? Just a glitch maybe?
Post #76251 15th Aug 2011 2:57am
See my thread over in the technical section but mine has now cleared. Did the same as yours and was very worrying as soon after the engines been running and you move off, all hieght lights go off!
I reckon its a hieght sensor problem so will need to check these out at some point as the car has recently had a light underwash with a jet wash at the local hand car wash place so this may have caused it...
Post #76255 15th Aug 2011 7:29am
