Home > Maintenance & Modifications > EAS Fault diagnostic
United Kingdom 2004 Range Rover 4.4 V8 Vogue Auto Oslo Blue
Right, my RAC turned up this morning and cleared my EAS in no time at all. The only fault in the EAS was "Too much energy for regulation needed: front axle". Does anyone have an idea what this could be or is it a random error that might never turn up again?
As a side note i had very heavy steering since day one. i never drove another FFRR apart from a new 2011 before i got mine so just thought it was the norm on older cars. Cleared all the faults with the RAC as there were a lot due to battery on and off etc, but when i took her out my steering was light as a feather and turned the car into something even better! 04, 4.4V8, Vogue Oslo Blue with LPG.
Post #76465 16th Aug 2011 1:02pm
England 2005 Range Rover Td6 HSE Auto Cairns Blue
cant help re the error rob, but the lighter steering intrigues me..
Post #76471 16th Aug 2011 1:39pm
Honestly Stan it was like night an day. My wife had it on sat to take her Sis and other bridesmaids shopping an she came home complaining about swore arms she drove this morning an nearly ripped the wheel of turning a corner. 04, 4.4V8, Vogue Oslo Blue with LPG.
Post #76485 16th Aug 2011 3:03pm
you've probably reset the firmware to what it was supposed to be ...
Post #76486 16th Aug 2011 3:15pm
Firmware? Shocked 04, 4.4V8, Vogue Oslo Blue with LPG.
Post #76488 16th Aug 2011 3:42pm
sorry what i meant was reset the ecu's that control the steering bit, anyways whatever you did, it worked...
Post #76490 16th Aug 2011 3:54pm
To follow up on this i had the same EAS fault ping up. When i contacted Storey when i had it last time he said this fault was due to a leaking front strut. To test it i put it in off-road height before i went on holiday and expected to return to it slumped down on one side or both, but returned home to nothing! Still in full height!
Does anyone have any ideas? Could this be a legasy of a failing compressor?
On the pluss side steering is still great! 04, 4.4V8, Vogue Oslo Blue with LPG.
Post #82673 20th Sep 2011 8:35pm
ric355
2003 Range Rover 4.4 V8 Vogue Auto Buckingham Blue
I'd be more likely to believe it's a front airbag leaking than the compressor. The reason for this is that it is telling you it has to pump more air to keep the front axle level. That's a function of a leak rather than an inability to charge the air reservoir sufficiently. I have read elsewhere that the airbags don't always leak when the car is stood still. If you imagine there's a crack in the rubber, it'll open and close as the spring moves which would make it leak on the move and possibly not at rest.
Post #82729 20th Sep 2011 10:08pm
good point. BUT how do i know which ones got a home if the Censored wont give me a clue. 04, 4.4V8, Vogue Oslo Blue with LPG.
Post #82737 20th Sep 2011 10:29pm
Site Sponsor
United Kingdom 2011 Range Rover Supercharged Autobiography Auto Atacama Sand
I would be interested to know too....
We buy forum member cars - PM for a quote. http://www.garyelliott.co.uk/prestige_cars/
Post #82740 20th Sep 2011 10:38pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
ric355
Three approaches;
- Ignore it until it gets so bad it does actually go down whilst stood still and you can hear it hiss
- try some GOTEC LDS as recommended by Landrover (based on a Google search). You might be able to apply some and then drive it, although not too sure on that as I've never tried it.
- replace both struts. Struts should be replaced in pairs anyway as there is a damper as part of the strut (unless you only replace the airbag itself).
Of course it might not be a leaky bag or valve or pipe. It might be something entirely different.
Post #82753 20th Sep 2011 11:08pm
might give it all a good soaking with soapy water and see if anything obvious turns up. Its an expensive trial and error without any real clue as to the problem. 04, 4.4V8, Vogue Oslo Blue with LPG.
Post #82767 20th Sep 2011 11:49pm
United Kingdom 2006 Range Rover Supercharged Vogue SE Auto Bonatti Grey
Good morning... From experience, if you put the car on full height then stand with your back to the front wing and lift the wheel arch (only a couple of inches) if the bag has a hole you will normally hear a hiss when you take the weight off the bag...
That said, most i have seen cannot remain at height when parked overnight...
And yes i aggree, both front airstrutts need to be changed at the same time...
I CAN HELP WITH SUPPLY OF PARTS IF NEEDED...
Craig Thumbs Up 06 SUPERCHARGED VSE
2012 Facelift
Overfinch Conversion
22" Overfinch Alloy's & GAP Lowering Module
Jet & Ivory Interior with RE & Hybrid TV + LR iPod Kit
BRC LPG
Post #82775 21st Sep 2011 7:57am
SteveMFr
Site Sponsor
Hi Craig,
Just out of curiosity: can you do better than island 4x4?
http://www.island-4x4.co.uk/spring-front-r...-1254.html
RRC 2Dr, RRC 4Dr,
P38, and LM
Post #82781 21st Sep 2011 8:14am
@craig, can you reply to steve via pm please.. Thumbs Up ..............................
this is handy Wink
Post #82784 21st Sep 2011 8:22am
