Home > Maintenance & Modifications > Where did these come from?
Mr Tee
Scotland 2002 Range Rover Td6 HSE Auto Java Black
Have had a serious noise coming from offside rear, though it was the disc guard, removed wheel to find these screws rattling around between the disc & guard:
Any ideas where they should be ?
After removal, there is still a scraping noise coming from the same place, all ideas & thoughts greatly appreciated.
Post #77568 25th Aug 2011 6:33pm
trafpol
United Kingdom 2006 Range Rover Td6 Autobiography Auto Buckingham Blue
They look like the shim springs off the caliper 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #77571 25th Aug 2011 6:37pm
Mr Tee
Aha, father in law recently replaced the pads, what do they do?
Post #77572 25th Aug 2011 6:40pm
trafpol
They stop the pads from shifting about under braking - sometimes causing squeking - there are holes on the side of the pads where they go in, push the in with pliers and twist to lock them in place. Thumbs Up 2006 MY Autobiography. With 'toys'
Gone
Post #77574 25th Aug 2011 6:46pm
Scotland 2002 Range Rover Td6 SE Auto Oslo Blue
They are the pins and springs that hold the handbrake shoes in place. Number 11 and 12 in the picture below.
Post #77576 25th Aug 2011 6:48pm
trafpol
wow - you see Im always impressed at answers on here and the knowledge people have and the way the answer is clearly presented. Good post. Bow down
I meant shoes when I said pads.... Whistle 2006 MY Autobiography. With 'toys'
Gone
Post #77582 25th Aug 2011 6:54pm
stu
United Kingdom 2007 Range Rover TDV8 Vogue Auto Zambezi Silver
guess the father in law is in the chair for the beer for a week or two then.. Thumbs Up Current: TDV8 Vogue Zambezi Silver
Past: TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #77583 25th Aug 2011 6:57pm
The scraping noise is caused by the brake shoes rubbing against the disc as the pins are not there to hold the shoes against the backplate. You need to have them fitted as soon as possible before further damage and expense occurs.
You may find the hole in the backplate where the pins go through have corroded and the pins won't stay in place. If this is the case just buy a couple of retainer cups as seen in the picture below and fit them behind the backplate
Post #77587 25th Aug 2011 7:04pm
Mr Tee
Right, sounds as though they could have fallen out due to corrosion as there would be no reason to go near these for pad replacement? Do you nee to take the disc off to access the backplate?
Post #77588 25th Aug 2011 7:04pm
If he only changed the pads it will not be his fault, the handbrake shoes have to be accessed by removing the discs.
My bet is the holes on the backplate are corroded Thumbs Up
Post #77594 25th Aug 2011 7:09pm
Mr Tee
Thanks , going in for MOT on Monday, hopefully get the use of their 4 poster to get this fixed! Bow down for the great pool of knowledge on here!
Post #77600 25th Aug 2011 7:16pm
Won't pass without it being fixed Big Cry
Post #77605 25th Aug 2011 7:32pm
Mr Tee
Fingers crossed, we'll get the use of a lift pre-mot, if not, car off road!
Post #77614 25th Aug 2011 8:17pm
