Home > Maintenance & Modifications > Main Dealer Vehicle Health Check?
England 2002 Range Rover Td6 HSE Auto Alveston Red
Are they the same as the service inspection checklists, see link
http://www.fullfatrr.com/gallery/displayim...amp;pos=19
or do they do something different? If different, does any one have this checklist?
Have "RSW All Comms" in Hampshire - happy to help Smile
Current Combustion Engine Transports:
Range Rover 2002 TD6 HSE Alveston Red, Sand Leather
Audi 2004 Cabriolet Sport 3.0 (Amulet Red)
Mazda Eunos 1990 (Brilliant Red)
MG Midget Mk 1 1962 (undergoing restoration) (to be Nightfire Red)
Post #78458 31st Aug 2011 1:43pm
dan_uk_1984
I may have one @ home I can scan in for you.
The Health Check is a free service the dealers do. I had it done on my P38 once, it was actually suprisingly useful. They picked up a leak in my valley gasket (although to be fair it turned out to be a rocker cover just needed screwing down a bit tighter)
They do things like check tyre wear at 3 points, check brake pads & discs etc. Frankly everything that you pay £300 for an inspection for less the oil & filter change!
More info here:
http://www.teamvalleylandrover.co.uk/pages...-check.php
Post #78461 31st Aug 2011 1:54pm
GregP
United Kingdom 2002 Range Rover Td6 HSE Auto Adriatic Blue
I had one done when my car went in for diff recall. They told me everything was fine although there was no paperwork etc so they may have not bothered. When others have had one did the dealership give you a "write up or checklist of health check?? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #78464 31st Aug 2011 2:30pm
No paperwork, but tyre depths were reported. I have some rust bubbling up on lower rear wing, they didn't report that, nor my knackered fog lights (most of the silvering has corroded away), hence why I'm after the checklist to see what they are supposed to do, in their "complementary" way Wink
Post #78584 1st Sep 2011 1:28am
RRVSE
United Kingdom 2006 Range Rover Td6 Vogue SE Auto Java Black
Just had an MOT today at Stratstone in Bury ( £29 at the moment by the way!! ) and they did a vehicle health check and it uses a traffic light system ( i.e. red = bad amber = warning green = good ) and covers:-
External :- Engine smoke/noise Brake/cluth/transmission operation mirrors/glass/locks
Wheels & Tyres :- Inner / MIddle /Outer tread depths . Check spare Check wheel alignment
Brake pads :- Tells you depth when new, current depth , useable depth left & recommended depth at which to change
Brakes :- Disc condition fornt and rear Parking brake Brake fluid condition
Antifreeze Condition A/C Vent temperature
Lights/Electrics/Heating :- Lights internal/external Wiper/Washer/Horn Warning lights/check control messages Heater/Air Con Operation Interior/ Safety/Seat Belts
Underside:- Exhaust System / Catalyst Steering / Suspension Vehicle Fluid Leaks Driveshafts/Joints/Gaitord/Mouldings Wheel bearing/Hub/Wear/Noise Hoses/Pipes/Cables
Engine Compartment:- Oil/Fluid/Coolant Level & Leaks Alternator/Belt/Battery Condition Engine Oil Level / Oil Topup
Obviously , a fair few of the above are covered by the MOT anyway , but OK for free. Steve
Main car : FFRR Vogue TD6 SE (06MY - Sept)
Other car : Vauxhall Lotus Carlton
Past cars : LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #78878 2nd Sep 2011 4:41pm
