![]() | Home > Maintenance & Modifications > Trim removal |
| Gazellio @ Prestige Cars Site Sponsor Member Since: 22 Jan 2010 Location: SITE SPONSOR, Chilterns, UK Posts: 4072
Anybody have experience of removing the trim that surrounds the drivers window/mirror/access switches as I am fitting a replacement that I know pushes on but I want to know which end to pull up first to remove old? |
Just tried does not seem to want to pull off.... |
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3019
Is it the switches panel? |
Yes!
| RRUK Member Since: 08 Jun 2007 Location: UK Posts: 3444
I take it you have removed the door card? You access them all from behind I think THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
I think from memory the door car has to be removed to allow the switch panel to come off |
OK guys I thought it popped off but looking at the new trim I think its screwed in from behind the door card |
Nothing in WIKI or search on Door Card Removal ?.
Now that I am expert at - will try and get back |
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8158
Perfect Stan but I WILL lose that first bolt |
get mini gaz to help you gary... |
Oops forgot the 10mm bolt |
