![]() | Home > Technical > Lower Tailgate Electrics |
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 980
fan? is that my new nickname now |
| kingpleb Member Since: 07 Jun 2011 Location: Kicking STBX to the curb where she belongs! Posts: 1996
DAM and double DAM.
Anyone?? |
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3019
Are you getting a voltage reading at the switch or actuators? |
I haven't got that far yet im afraid |
I would expect to see 12v at the switch. Also I would have checked this before buying all the new parts |
The loom was shot and had seen some bodgework before so i had to replace it as i don't like untidy cabling |
Well my 9083 is on the bay so i ordered a cheap draper unit from amazon for £12 and it seems turdy and OK enough so will be giving the units and good going over tomorrow as should only take about 10 minutes to take the panels off and connect to each one.
Well I've now tested at the switch and actuators and no power at all. I do notice the switch has 3pins but the cable is only 2pins at the plug but still it goes open circuit when activated |
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 347
My lower tailgate stopped working a couple of days ago. The motor doesn't sound when I press the button but the tailgate will open manually of course.
Sorted now.
Thanks mikey, think I've tried this but I'll give it another go before it goes to an indie for its wheel bearing this week an I ask them to check the bcm incase it's totally locked out from the previous owners wiring attempt...
Glad yours is fixed now though and a simple enough fix! FFRR 2005 facelift With an SC Grille and that's it!
Is anyone playing around with their tailgate at all and able to run some electrical tests on their release button and the wiring to it at all??
