![]() | Home > Technical > car wont turn over! |
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8158
sounds like the battery..you may have lights etc but not battery power to turn it over... |
| PaulB Member Since: 17 Jul 2011 Location: West London Posts: 199
Yep, I would start at the battery.
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1862
mine did this yesturday id put all my money on your battery |
| killatomato Member Since: 15 Jul 2011 Location: Wirral Posts: 30
Hi guys it's happened again, so I called RAC. Guess what happens as soon as he arrives the thing fires up. Then we tried about 20 times and only 2/3 times it did not turn over. So it should not be the battery but a faulty part - lock barrel? Solenoid? |
Hello, anybody have any ideas? I really don't want to go to the stealers! |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the sea Posts: 583
Gearbox inhibitor switch?
still reckon its the battery....how old is yours ,if over about 3 years then its time to change.. ..............................
ok then, in the words of homer, 'i dont know'. ..............................
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3019
Poor earth to the starter, knackered starter, broken wire, inhibitor switch on gearbox, blown fuse, there are so many things that could cause this problem and only by working through some of the more common faults will you be able to eventually find the cause |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1314
My money would be on a battery too, mine used to do it if the car had been standing for a week or so. 2006 Mercedes CLS
| DavidP Member Since: 20 Oct 2010 Location: Keerbergen Posts: 178
Mine does this occasionally, even though she starts fine after removing and re-inserting the key. |
| darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 418
i had this problem too, it turned out to be a faulty module in the steering column 2002 td6 vogue, 06 supercharged facelift
Darrenmax, do you know what the module was?. |
