| Is BCM cooked or can it be recalibrated? | |
DTC (read with GAP IID Tool):
U201B-54 (2F) Control module calibration data 2 — System programming failure — missing calibration
(logged on 03-07-2025 13:33:13 at 154,790 km)
Symptoms:
Steering column not motorised at all — no movement via memory seat recall or via the manual column switch.
Live Data recognises switch requests, but hall sensors are either showing as N/A or reading out-of-range. I suspect this is why the BCM is reporting a calibration issue.
During the investigation, I also found evidence of a previous repair or intervention — someone had clearly messed with the wiring at connector C0587 (rear of the Battery Central Junction Box / BCM).
The wires had been badly bodged, in addition, most were melted together.
 | | Click image to enlarge |
I had to sort out the loom first before any further diagnostics could be carried out. That alone took a good few hours to tidy up.
At least now I am confident there are no shorts, and the wires are connected properly — or as best as possible within a connector that looked as if it had been opened with a chisel and sledgehammer.
I have to admit: I then did something which probably shouldn’t be attempted — I installed a BCM from a donor vehicle to test the column and harness, and to check if it would make any difference. At that point I nearly caused problems with the KVM, since the replacement BCM was not programmed to this VIN. That said, with the donor BCM fitted, the steering column worked, meaning I was able to operate it via the switch.
To get the vehicle to recognise the keys again, I had to reset the KVM. Pulling fuse P17 from the glovebox fusebox (BCM) didn’t work, so I disconnected the battery and bridged positive to ground (with the battery fully disconnected!). That reset things, and the keys were recognised — the car started fine.
Unfortunately, after reinstalling the original BCM, the steering column is still non-functional.
Question:
Has anyone seen this DTC (U201B-54) before, or had steering column adjustment issues traced back to the BCM? _________________________________________________________________________
Krzys
