Home > Technical (L322) > Towing electrics not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
i would guess the trailer fuses but you get that message so that gets confusing..
13th Sep 2011 9:12am |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
do you have the towing module fitted?
13th Sep 2011 9:13am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
When I did mine it was just plug ‘n play – here’s the relay connections :
13th Sep 2011 9:18am |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
Isn't the white Siemens box the towing module? |
13th Sep 2011 9:36am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
did u connect the earth cable thats by the rubber grommet that enters the car it attaches to the bumper bolts i think onto no6 Range Rover
13th Sep 2011 9:39am |
No, as I thought that was just a failsafe and there were earth in the main connectors. I'll attach them and try again. |
13th Sep 2011 10:37am |
just a thaught as it can be missed but i hope it solves your problems onto no6 Range Rover
13th Sep 2011 11:21am |
I've checked all the fuses, unplugged and replugged everything but now it's getting ridiculous.
14th Sep 2011 3:41pm |
the trailer socket might have a loose/dodgy connection? and is giving the wrong signals to the range.....can you try another socket maybe.. |
14th Sep 2011 3:45pm |
Can't try another socket but I'll pull this one apart and see if the connections are all good. |
14th Sep 2011 3:51pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
There's no corrosion in the socket causing shorts circuits from terminal to terminal by any chance? |
14th Sep 2011 3:55pm |
I checked for shorts across all the terminals and there were none. Continuity up all the cables was fine so I plugged it all back together and now it works fine.
14th Sep 2011 5:47pm |
something made the car think that..its process of elimination i'm afraid so next step maybe the relay.. |
14th Sep 2011 5:53pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Interesting they obviously changed the loom at some point; my loom, which I bought second hand, doesn't have a relay at all. |
14th Sep 2011 6:26pm |
