![]() | Home > Maintenance & Modifications > 2010 brembo brake calipers will they fit ? |
| speedymarktd6 Member Since: 20 Nov 2008 Location: worcestershire saurcy Posts: 554
hi all does anybody know if the 2010 brembo 6 piston calipers and 380mm discs as fitted to the s/c fit a 2005 with 19'' ?
| alanm_3 Member Since: 19 Feb 2011 Location: Glasgow Posts: 1305
AFAIK Brembos will only fit with 20" wheels.................. Got - 2008 TDV8 Vogue SE in Java black
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8158
there are 2 size discs and the 380mm ones i believe are the bigger ones and like alan says ,they need 20'' rims.. |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Geneva Posts: 431
My 2007 TDV8 Vogue has Brembo's and they do fit with a 19 inch wheel |
| Trommel Member Since: 05 Jan 2010 Location: UK Posts: 328 |
They're not the same Brembos. |
I'm sure I read somewhere that the wheel offsets on newer wheels were changed to accomodate Brembos? Or as maybe as Stan says, these are the smaller Brembos? Got - 2008 TDV8 Vogue SE in Java black
i think there are 344mm ,360mm and 380mm diameter brembo discs...i'm sure dan [duckworths] will confirm.. |
The 4-piston Brembo calipers are half the size of the 6-piston ones, and use a smaller-diameter disc. |
