![]() | Home > Technical > Squeak |
| Dave ray Member Since: 19 Sep 2011 Location: Liverpool Posts: 16
Squeaky suspension any ideas |
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8158
kill the mouse.. ..............................
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 853
not alot to go on but ill stab in the dark at front balljoints. 2004 black Vogue TD6 |
I have only had it in the last 2 days little bit anoying is it a big job to fix |
| ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 277
If you have side steps it can be helpful to stand on them and bounce the car (not whilst driving I might add!!). You might be able to tell whether it is coming from the front or rear and possibly which side. Bit easier than when driving, where I find it tends to be harder to see where it's coming from.
Thanks for the advice it does it when turning slowly and slowing down to stop it stopped for a day then came back I can only describe it as a squeak/clunk noise if that makes any sense |
Sounds like it's coming from the front left |
haunted house door = balljoint.
Mine just hit 105k is it a big job |
nope not a big job.
Your not wrong £89 including vat thought my v10 touerag was temperamental these are in a different class |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 393
yes but these are cheaper and easier to repair than the Touareg!! the final straw for me was thick end of £2k to sort out the rear brakes on mine.
