Home > Maintenance & Mods (L322) > Stuck alloy |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
a real good go with a rubber mallet, which you have probably done already or place a large piece of wood on the inside rim and hit the wood with a proper lump hammer...make sure you have a couple of nuts screwed on a little bit otherwise when the wheel comes it'll get damaged.. ... - .- -.
21st Sep 2011 8:12pm |
A fairly common problem. I used a length of 3x3 wood against the inside of the offending rim, end on. Hit the other end with a lump hammer. Took 2 blows for mine to come off whereas the rubber mallet was a complete waste of time.
21st Sep 2011 8:14pm |
Bigger hammer and a lump of wood usually works eventually. |
21st Sep 2011 8:24pm |
A few hard kicks on the outside of the tyre wall usually works |
21st Sep 2011 8:33pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Thanks chaps - will try end on piece of wood and lump hammer tomorrow ! |
21st Sep 2011 9:40pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
21st Sep 2011 9:57pm |
Try loosening all wheel nuts by only two or three turns, then jack the other side of the car as if removing the opposite wheel (placing more vehicle weight on the offending wheel). Making sure the vehicle is safe and supported (jacked correctly) then hit the offending wheel with your mallet... I had to do it on the side of the road one night way back when and it worked in an "emergency puncture" scenario...
21st Sep 2011 10:21pm |
