Home > Maintenance & Mods (L322) > Running board removal |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
If they are fitted correctly? The front mudflaps will have 10mm bolts drilled through the lower wing plastic panels holding them flush to the wings... If you remove them you will be left with two holes per side... That said, you can simply install standard front mudflaps utilizing the same holes!
22nd Sep 2011 10:42pm |
