![]() | Home > Maintenance & Modifications > Steering Damper on TDV8 ? |
| googsy2 Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 815
Carlos I had this problem when I fitted a set of 20's to my Disco3 no amount of banlacing would sort it. The fix was to fit spigot rings which fixed the issue. Its worth checking to ensure there is no play on the wheel when fitted to the hub before you tighten wheelnuts. Hope this might help. Present :2008 TDV8 HSE
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3019
LR don't recommend 22" wheels |
