Home > Maintenance & Modifications > ANSWERED: Fitting instructions for OEM side tubes
A1GSS
Hi Mick
Earlier in this thread Googsy posted a link to fitting instructions for non-OEM tubes; the steps use the same fixings so the procedure would be identical. These are far easier to follow than Land Rover's attempt...
http://www.powerfuluk.com/products/range-r...e-kit.html
It was simple enough apart from the nut that snapped off inside the chassis; if this doesn't happen to you it's about 1/2 an hour each side.
Having a quarter inch socket set with a universal joint in it would make life easier for the side bolts, bit awkward with a spanner. Graham
Formerly known as Antoniasdad
GONE: TDV8 FFRR Vogue in Stornoway Grey / Jet
TDV6 Discovery 3 in Stornoway Grey / Alpaca
Post #90675 6th Nov 2011 3:14pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
2010 Range Rover TDV8 Vogue SE Auto Santorini Black
Post #90677 6th Nov 2011 3:18pm
Green
United Kingdom 2004 Range Rover Td6 Vogue Auto Giverny Green
Mick
Dan posted the OEM side step instructions here:
http://www.fullfatrr.com/forum/topic8304-15.html
Hope this helps!
Post #90686 6th Nov 2011 4:10pm
Cheers Thumbs Up
Post #90694 6th Nov 2011 4:36pm
