![]() | Home > Technical > "rear water ingress" |
| JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 783
I fitted new gaskets made from Evo Stick Flashband, which is a lead free self-adisive flashing strip
| RR8701 Member Since: 11 Aug 2011 Location: Scotland Posts: 277
Justin,
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 203
Good job Justin |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the sea Posts: 583
When I tested the door seal with a hose pipe the leak was evident almost instantaneously. By removing the hose and re-applying I could stop and start the leak at will. Top left corner. |
| Diver Bryn Member Since: 16 Jan 2012 Location: Durham Posts: 12
Possible cause to the condensation is the air compressor situated under the rear spare tyre (Mine has been making some disturbing noise's over the past few months) coupled with about 1/4 litre of condensation pooled below it. I am looking at this option this weekend. Regarding the sat navs that were ruined in the rear right quarter panel from previous post's due to water ingress. Mine had the same problem where the power pin correded and broke off. My good electronics friend disassembled the male ten pin connector block and rebuilt the unit, it is now good as new. The L/R dealer wanter in excess of £1,500.00p to replace it!!!
Is rained for the first time since I replaced the tiow bar armature gaskets, and as suspected my spare wheel well is wet again.
| Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 125
I have been following this post with some interest as i too suffer from the same problem. I have applied the obligary vaseline around the armature gasket area and still have water ingress somewhere into the rear bootwell. I had the same problem on my old P38.
Your 100% Correct when it comes to Land Rover using us as the guinea Pigs to fault find there design flaws. I had one of the first 2005 model year touch screen Vogues that was blighted with electronic Gremlin's in the end the dealer was legally forced to take it back and swap out for a new on. Ironically what other vehicle is out there that even compares. Perhaps land rover will add another fitted extra as standard to the Rangee........A bilge pump! Diver Bryn
I went out to further investigate my leaking boot and my spare wheel well has collected over 5mm of water over the last couple of days |
Whilst painstakingly trying to resolve this leak. Your 100% correct guys water is definately coming in from near side rear panel in corner. Rain water is seeping in and when washing car pouring in. hopefully now fixed with foam Gasket and as a precaution new tail gate boot seal. :thumbsup: Diver Bryn
