![]() | Home > Technical > "rear water ingress" |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 203
| RR8701 Member Since: 11 Aug 2011 Location: Scotland Posts: 277
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 874
Your hammer obviously want big enough or you wern't hitting said problem hard enough. These are typical SBE's! |
| Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 125
Guys this could be good news as my boot well was swimming aftre the rain today, jusdt dried out what i could and then have sealed mine armatures with good old vaseline so am hopeful that this is the problem in that area. Will let you know how it goes
| JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 783
excellent work guys |
Ive heard of that problem as well - check your boot seal at the corners up near the hinges - the metal inside the seal can corrode and make the seal bulge - the water gets in there and tracks down the pillar - my seal is not ggod at these corners and my new one just arrived today from Dan.... 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Hi SC yes i have checked the seal and seems to be ok, the water seems to be coming from inside the metal boxsection which is what makes me think that the hinge area is the problem as these bolt through into it as there is no access to to the bolts inside any where, i wonder if there is a gasket under the hinges as well!!??? Oh well have to get the vaseline out again, car bwill be held together with it soon. My next RR i will ask LR to put a jar in the boot for free !! |
| VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 222
Interesting - I had some leaks in the boot before I took off the armatures and replaced with towbar armatures - but as part of that work, I did add some silicone to the neaprene seal between the armature and the body as a "just in case" measure and have now not had any leaks since ... |
*****UPDATE*****
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 1473
I have a LR Fixed plate towbar for sale if interested |
Well some fairly heavy rain today and a quick check tonight found my boot nice and dry with no water ingress.....phewww |
Hi CG,
Hi RR8701......I have to say that I failed with the pics as I did it at my mates garage and had forgotten my camera and phone......
