Home > In Car Electronics (L322) > CD Changer jammed |
tilemanvogue Member Since: 22 May 2011 Location: Aylesbury Posts: 24 |
Can anyone help with my problem. Is there a way to remove the 6 disc changer cartridge from the unit, it seems to stay put when press green eject button, just makes a whirring sound and nothing. Is there a way to remove cartridge without taking out the whole unit
10th Nov 2011 10:26am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
hit it with a hammer.... ... - .- -.
10th Nov 2011 10:27am |
ok seriously ,open the cd flap, hold the eject button and hit the cartridge with a small hammer...
10th Nov 2011 10:42am |
Thanks for reply. I will try that out and see if it helps Discovery 3.9
10th Nov 2011 10:44am |
Failing the above mentioned , Open flap hold eject button , using a wallpaper scraper you can get , either slide inside the top of the CD changer or underneath and do a bit of jiggling about with it but not with too much force tho (scraper) …. before all the smartass replies fire in ... ====================================
10th Nov 2011 10:50am |
Cheers Mick
10th Nov 2011 10:56am |
Well that done it. It was stuck fast, so destroyed cartridge to get it out. Now just need new cartridge, any ideas where from Discovery 3.9
10th Nov 2011 11:27am |
http://www.ebay.co.uk/itm/Rangerover-range...884wt_1156
10th Nov 2011 11:40am |
Thanks again for your help Mick, much appreciated.
10th Nov 2011 11:44am |
Didn't mean for you to destroy your cartridge tho ... ====================================
10th Nov 2011 11:47am |
I know. I just kept gently tweaking it out, but no luck, so got a little annoyed, thought that it was the easiest way to solve the problem. Just ordered new cartridge, thanks for the ebay link Discovery 3.9
10th Nov 2011 12:06pm |
hammer must have been to big... ... - .- -.
10th Nov 2011 12:29pm |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
This was great. Just had the cassette jam yesterday. For a moment I thought I was working on my Wrangler. 92% of those can be fixed with a good wack from a Manchester screwdriver. |
28th Sep 2015 8:52pm |
