![]() | Home > Technical > Creaking and groaning when turning steering |
| RRUK Member Since: 08 Jun 2007 Location: UK Posts: 3444
Hmm, first things first, don't discount a steering issue.
Here's my thread
| oodathort Member Since: 01 Nov 2010 Location: just there Posts: 190 |
Lower ball joints |
Is that a diagnosis or an outburst? |
| ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 49
Its not a pump or pipe issue. pas is working fine. Its a clunking groan which can be felt through the steering. At 1 mph and above it does not do it at all. I think its a dry ball joint or the top strut bearing. I have replaced the front lower arms in the last year and the rear lower arm rubber bushes and checked all the lower ball joints. Is the strut top bearing a sealed unit? I'm going to get the misses to turn the steering lock to lock while Im under it tomorrow and See whats going on. |
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 853
from the front suspension i had a;
