Home > My Range Rover > bye bye ffrr
gl
Sweden 2011 Range Rover Autobiography TDV8 Bournville
bye bye ffrr
Thanks for all the helpful and use full tips as well as interesting topics i have seen here during the last year. Land rover gave me a new car last week but it was not as i wanted it so the dealer decided to give me back my money instead. i really wanted the ffrr but if i spend over 120 000 pounds on a car i want it to work. I went to bmw who gave me a good price on an Active hybrid 7 instead which will hopefully keep me happy for a while. hope to get a new range rover when the new model comes out. 2011 tdv8 autobiography bournville / Arabic
2012 tdv8 autobiography orkney gray / jet/jet waiting
Post #92356 15th Nov 2011 2:49pm
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
What was wrong this time?
Can't imagine an other oil leak? RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #92555 15th Nov 2011 10:48pm
gl
the whole thing started to fall appart. the last drop was when i closed the tail gate and one of the tail lights fell out and broke against the ground. then i just went to the dealer and parked it there and refused to get it back. 2011 tdv8 autobiography bournville / Arabic
Post #93681 22nd Nov 2011 9:28am
Vogue
that sounds very odd, what other problems did you have?
Post #93706 22nd Nov 2011 11:41am
roverron
gl,
Here is the list you posted with trouble you had on the MY 11
1. It started day one with an oil leak. That took 4 weeks to fix.
2. The front door was not mounted correct at the factory
3. All the wiring for the surround cams were exchanged
4 change of revers camera
5. The stereo stopped working
6. Oil leakage into the turbo. The car is in the garage for another month
7. The stereo is in different languages in the different menues
8. The car doesnt start. The start enginge has corroded due to wrongly mounted drainage pipe
9. Batery problem
10. Today one of the back lamps just fellout when closing the boot!
Do you really mean the backlight fell out on the new MY12 also?
It just can't fall out, it's secured with two clips and two screws.
Someone doesn't like you having a FF and (un) screws you..... RR 2012MY TDV8 AB ipanema sand
Post #94220 24th Nov 2011 7:40pm
gl
not on the my12 it was also on the my11. but when i alsked for a full money refund if the my 12 would have simular problems they decided to give me the money back from the my 11 and sell the new one to another customer which im sure will be very hapy with the new car. www.blocket.se/malmo/Land_Rover_Range_Rove...11&w=3
if you click on the above link you will get to the car ad that is out on the my 12 that i didn't pick up. 2011 tdv8 autobiography bournville / Arabic
Post #94347 25th Nov 2011 11:14am
