Home > Maintenance & Mods (L322) > Help from V8 owners RE front side light housings
Matt@obsidian
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi peeps. Another annoying little issue I thought I could easily solve was a loose near side side light housing, but on closer inspection it appears someone has broken (I assume whilst trying to change) the arm that the big White nut sits in that tightens to pull the housing back. So consequently although you get the inner clip in place it pops back out due to this broken arm. If this males any sense Rolling with laughter can I replace the arm or is there an alternative fix?
Cheers for any ideas Range Rover 4.4 V8 Autobiography
Mustang Mach 1 (1971 in grabber green)
Honda civic 2.2 diesel
VW crafter with ICE
Post #92507 15th Nov 2011 8:51pm
Is it the arm or the big white plastic nut?
The white plastic nut on mine was knackered and I heated an 8mm nut and melted it into the plastic, I then removed the metal nut once it had shaped the plastic and put some Araldite in to hold the nut in place....sorted
Post #92509 15th Nov 2011 9:00pm
Matt@obsidian
No it's the arm the nut goes through. It's snapped where it connects at the other end. I assume it's cause it's so tight they just ragged it off. The nut is tight on the housing, it's snapped at the back Range Rover 4.4 V8 Autobiography
VW crafter with ICE
Post #92510 15th Nov 2011 9:04pm
You should be able to fabricate something to replace the broken part
Post #92513 15th Nov 2011 9:11pm
Matt@obsidian
Yeah that what I figured it would have to be. Just not an awful lot of room in there lol. I will get my thinking cap on at weekend when I have the light on my side. Cheers for your input Thumbs Up Range Rover 4.4 V8 Autobiography
VW crafter with ICE
Post #92520 15th Nov 2011 9:25pm
