Home > Maintenance & Modifications > Mirror approach lamps - led bulbs
Blackbird51
United Kingdom 2004 Range Rover Td6 Vogue Auto Java Black
Hi. My first post and undoubtably not my last. I have 2004 td6 Vogue with approach lamps mounted in mirror housings. I have tried to replace the standard w5w bayonet type bulbs with brighter led type bulbs only to find that they won't work. It seems that the system will allow for 1 led to be fitted with 1 filament type but when 2 LEDs are fitted neither works. Anyone got any answer/ideas?
Post #93403 20th Nov 2011 3:04pm
2010 Range Rover TDV8 Vogue SE Auto Santorini Black
have a read through this … might help
http://www.fullfatrr.com/forum/topic2355.h...rror+bulbs
Post #93404 20th Nov 2011 3:10pm
daveo
United Kingdom 2004 Range Rover 4.4 V8 Autobiography Auto Java Black
yep Thumbs Up found this, did mention it in a post a while ago, you need to put a small resistor with the same value on both sides, it then falls the system into thinking the normal bulbs are still fitted. V8 facelift Range Rover Autobiography 22" wheels.
Post #93410 20th Nov 2011 3:49pm
A1GSS
Or, you might have both of them in the wrong way round. LEDs are directional. I replaced loads of filament bulbs on my D3 with LEDs, no issue at all. The indicators DO need resistors though. Graham
Formerly known as Antoniasdad
GONE: TDV8 FFRR Vogue in Stornoway Grey / Jet
TDV6 Discovery 3 in Stornoway Grey / Alpaca
Post #93413 20th Nov 2011 5:18pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
Blackbird51
Cheers for fast responses LEDs are fitted correctly. Reckon it must be the resistor issue. Now to find some suitable led bulbs. Will post result.
Post #93416 20th Nov 2011 5:44pm
England 2005 Range Rover Td6 HSE Auto Cairns Blue
its the same with the map reading lights, normal leds dont work..
Post #93432 20th Nov 2011 7:35pm
Reformed
England 2003 Range Rover Td6 HSE Auto Java Black
This would explain that problem then! Embarassed
I thought it was me doing something wrong so I gave up messing around and put the normal bulbs back in! Reformed
Post #93446 20th Nov 2011 9:05pm
Blackbird51
Tried 4smd LEDs with built in resistor. Things are improving but only just!! Both LEDs illuminate but only for 2-3 seconds. No fade. Does anyone know the resistance required to get correct operation?
Post #93804 22nd Nov 2011 8:13pm
ric355
2003 Range Rover 4.4 V8 Vogue Auto Buckingham Blue
Seems to be an awful lot of effort just to put some LEDs in. I'd have thought you're better off with normal bulbs, as LEDs are all pretty directional and you want the light to spread out a bit more for the approach light to function suitably.
Post #93807 22nd Nov 2011 8:25pm
Glideman
Location: as far away from any Land Rover product as I can get!
United Kingdom 2003 Range Rover 4.4 V8 Vogue Auto Zambezi Silver
Are these LED bulbs not illegal for use on the outside of a car?
Post #97873 15th Dec 2011 6:12pm
leds are ok to use..
not sure whether leds will fade as they are either on or off.. ..............................
this is handy Wink
Post #97884 15th Dec 2011 7:05pm
United Kingdom 2006 Range Rover Supercharged Vogue SE Auto Bonatti Grey
When I changed all my interior lights for LED lights I cut and soldered the live wire to the mirror puddle lamps into the lower door panel illumination circuit, so they work without the fault and a bonus is, they stay on with the interior lights for longer!
Much better now Thumbs Up
Craig Thumbs Up 06 SUPERCHARGED VSE
2012 Facelift
Overfinch Conversion
22" Overfinch Alloy's & GAP Lowering Module
Jet & Ivory Interior with RE & Hybrid TV + LR iPod Kit
BRC LPG
Post #97925 15th Dec 2011 11:45pm
edit on my previous post..
the interior leds do indeed fade as i have just realised by looking at mine. Embarassed ..............................
this is handy Wink
Post #97953 16th Dec 2011 9:18am
