![]() | Home > Technical > Whats the easiest way to get a secondary key for my pre-05 |
| Joe90 Member Since: 29 Apr 2010 Location: Winchester Posts: 1072
@ daveo re your last two posts - this is exactly what I understood to be the case, that you needed a key to come from LR if you needed another key. There seems to be a lot of mis-information here (not yours daveo |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 1477
its one of those things, like mapping,if you have the equipment to do then your laughing..when i use to chip playstations it was money for old road, a £1.25 chip and 4 wires to solder and there you go £40. until every one started doing it and it came down to £10. the same in the key programming, you can buy the key cases now for £8 and the transponder chip are about a £5 so thats around £13 then just needs programming and as you need a bit of kit thats were the money is..so if there is any one on this forum how knows someone that can do this programming 100%, ask them if they are interested on doing a good price for forum members.
| CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 187
sorry got carried away with my self, the mapping is for the engine ecu and gives you around 20bhp but better torque and sorts out those flat spots.
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 846 |
That wasn't the case when I coded a key from another car to work on mine, using the technique posted on this post. OK it was a BMW E38, but same key, same transponder same technique!
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 980
pre 05 FFRR key would be £175inc vat, will come programmed and cut to your car.
Thanks Dan, that helps to clear all that up |
| sidmini Member Since: 20 Sep 2010 Location: kent Posts: 41
Daveo could you kindly give me some more info on the remapping of the 4.4, where do you get it done and what do they send you? thanks |
