Home > Maintenance & Mods (L322) > TD6 Service Intervals |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 |
i would'nt be happy if mine went that long between services, if it sounds and drives ok i wouldnt let it put me off though. just service it more frequent than what it has been done, i change the oil and filter every 3000 miles and all the filters and brakes once a year along with the gearbox oil and filter. |
22nd Nov 2011 12:38am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1651 |
You change your gearbox oil yearly..?? Ash
22nd Nov 2011 9:15am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3689 |
depends how you drive it, and the service indicator will tell you when a service is due. Mine used to come on at every 12 to 15k miles and if the miles were not up to this level it would come on annually. So yes your service history looks right for the mileage.
22nd Nov 2011 11:36am |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
Yep, would have to agree with that. The only real way to slow the wear of the GM box is to change the fluid every year or 20K miles or so. Just had mine rebuilt, and strongly advised to do this if I want it to last more than 100K this time... |
24th Nov 2011 7:53am |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
mines still got 6k on the computer but its been 14months so gave it an oil change for now 2004 black Vogue TD6 |
24th Nov 2011 6:24pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Mine was serviced when the computer asked for it, always about 13K and never had any problems. Discovery 4 HSE
24th Nov 2011 6:47pm |
[quote="comports"]You change your gearbox oil yearly..
24th Nov 2011 11:10pm |
It's quite interesting the difference of opinion from other threads. It was suggested that the GB oil was "Sealed for life" but I think the conclusion to that was sealed until the warranty had run out. A lot folks on here suggest leaving it until it cuases an issue as fresh oil only serves to release any previously "stuck" material and that's what could cause an issue.
25th Nov 2011 9:35am |
If the box has got high milage on it, I would probably leave it - but once it fails (and it will ) once a rebuild has been done, then keep on top of the services |
26th Nov 2011 2:52am |
