Home > Technical > Exterior Mirror Dip when reversing
Simes
United Kingdom 2004 Range Rover 4.4 V8 Vogue Auto Adriatic Blue
Mine don't.
Followed the instructions in the manual - mirror select set to drivers side - into reverse - nothing. Car in reverse, set the mirror to a dipped position manually and save it - nothing else happens - it just stays there sullenly...
Any thoughts? Could it be disabled? If it is, can I re-enable it?
Post #93888 23rd Nov 2011 12:00pm
nbunney
It only works on the near side
Post #93889 23rd Nov 2011 12:01pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
Simes
I know.
Post #93891 23rd Nov 2011 12:05pm
nbunney
Re: Exterior Mirror Dip when reversing
Post #93892 23rd Nov 2011 12:29pm
Simes
nbunney wrote:
According to the manual, the mirror dip will only work when the mirror select switch is set to the drivers side. But mine doesn't work regardless of where the mirror select switch is set!
Post #93893 23rd Nov 2011 12:31pm
Cappo
2006 Range Rover 4.4 V8 Vogue Auto Java Black
Is it possible to adjust the angle of dip? Mine goes almost horizontal! The old P38 was much better in this respect!
Post #93905 23rd Nov 2011 1:36pm
Simes
Cappo: yes that's simple - just select reverse, adjust and store against the number button you are using for seats etc.
Post #93996 23rd Nov 2011 6:30pm
Roystonh
United Kingdom 2011 Range Rover TDV8 Vogue Auto Zermatt Silver
Hi
My new 2011 model has just developed wonky mirrors too - they dipped great but now have stopped moving down, something for the first service list. Not worried though, love the car :@) 2011 RR Vogue and MX5 20th Anniversary
Post #94684 26th Nov 2011 11:40pm
RRVSE
United Kingdom 2006 Range Rover Td6 Vogue SE Auto Java Black
Simes, not that it helps, but I can confirm what you say in that the mirror selector does have to be switched to the 'adjust the drivers side mirror' position else the near side one doesn't dip when reverse is selected. Bit dumb really, you'd think it would just automatically override the mirror setup switch in the first place! Steve
Main car : FFRR Vogue TD6 SE (06MY - Sept)
Other car : Vauxhall Lotus Carlton
Past cars : LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #94689 27th Nov 2011 12:53am
Cappo
Hmmm, doesn't seem to work..... Confused
Post #94694 27th Nov 2011 1:21am
fraserl322
Australia
2002 hse here, no mirror dip, and the passenger mirror seems to have no memory, the drivers side remembers settings, but the passenger side just stays where I move it to.
Any suggestions?
Ta,
Fraser
Post #123553 25th May 2012 12:14am
5IMON
Ive had two range rovers and both of them have had wing mirror problems , just my 2 cents
Post #123556 25th May 2012 12:33am
