![]() | Home > Technical (L322) > Loss of power and missfire on SC |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I had a similar though less severe experience recently whilst very low on fuel, just power loss on motorway, no eml, and was fine after I filled up! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
My M5 was continually going into limp home mode and being trailered back to the dealer, eventually it was diagnosed as being the MAF Mass Airflow sensors, in others words the oxygen sensors, they were replaced and it was like getting a different car in terms of the power, it released the full might of the 5.0 V8 which had been running poorly before.
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
The EML came on when i restarted and also a message saying the engine was running on reduced power. After filling up, the EML had gone off and there were no warning messages. |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
This?
Daveo might be able to tell you what the codes actually mean Discovery 4 HSE
Thanks for the info guys. |
here you go: from http://www.eobd2.eu/DTCL.asp
You VERY probably have a dodgy fuel pump as those are the exact 4.2 SC symptoms I suffered and Dan suffered when the fuel pump cannot "Jet" fuel from one side of the bottom of the tank to the other! Normally happens with about 65 miles to empty indicated.....
Better still, get the supplying garage to fix it for free! Discovery 4 HSE
Thanks Gary. I will return it to the garage next week as its still under warranty. |
Strange how this has happened Nick that SC never gave me any bother fuel pump wise .... |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
I'm saying nothing as mine is due a service and is looking at me funny.
Mick we have a theory that involves ESP and a pressure washer.... Discovery 4 HSE
Mick - As Adam says its slightly suspicious that they had the car for over a week to fix the cold start squeak and reverse camera, and the day after I pick it up I had this problem.
