Home > Maintenance & Mods (L322) > Door handle cable?
saj2421
United Kingdom 2006 Range Rover SE Td6 Java Black
Door handle cable?
Just went to open the drivers door, pulled the handle, heard a click, and now the handle doesn't open the door!
Door opens fine from the inside.
Any ideas and is it a job I could tackle myself?
Thanks
Post #94169 24th Nov 2011 5:28pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Wow - just had the same happen to me on my rear passenger door Shocked
Awaiting replies eagerly !
Post #94208 24th Nov 2011 6:38pm
Just did a forum search and found this thread for you: (+door +handle +cable !!)
http://www.fullfatrr.com/forum/topic3712.h...ndle+cable
Also check out powerfuluk, pretty certain they did a video on taking the door card off (maybe about wing mirrors) .
Post #94214 24th Nov 2011 6:57pm
saj2421
Thanks for that pal. Think I will have a go myself Thumbs Up
Post #94227 24th Nov 2011 8:08pm
ric355
When taking the door card off, you might break a few clips. These are the right ones:
EYC500280 DOOR TRIM CLIP G-CAT (G)
You can get them from www.brit-car.co.uk - 27p each.
Post #94251 24th Nov 2011 10:10pm
Norman
Scotland 2003 Range Rover HSE Td6 Epsom Green
Just had the same problem with the drivers door on my 03 RR. outside handle moves but doesn't do anything
Removed the the door card to see the cable had broken tight to the nipple on the outer door handle. I removed the cable completely, shortened the outer by 12mm, made a new nipple and fitted this the end of the cable allowing for the 12mm decrease in length. Refitted the cable to the door, works perfectly. Incidentely I have ordered a new cable, but I think the cause of my cable breaking was that instead of the nipple rotating as the outer door catch is moved, the cable was flexing tight to the nipple. I have put some grease on the nipple now which is allowing it to rotate. NC N C.
Post #94810 27th Nov 2011 11:04pm
