Home > Maintenance & Mods (L322) > Fitting new battery ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
masses of info on this , use the search function, but put the bonnet into service mode and get a stool to stand on.
9th Dec 2011 1:01pm |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 |
hi mate, if you check on youtube, you will find a video from powerflow uk or something and they should you how to put it in service mode.
9th Dec 2011 1:07pm |
I had no problem getting a new 110AH battery in without setting the bonnet in service mode, just dropped straight in first go.
9th Dec 2011 1:16pm |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
Dont forget to wait ten minutes after turning off the engine before changing Battery. |
9th Dec 2011 1:29pm |
.........and once the battery is fitted turn the steering wheel fully left then full right to set the steering parameters.. |
9th Dec 2011 1:35pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
This is the youtube link RR8701 was referring to:
9th Dec 2011 1:43pm |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 221 |
Does anyone know if you have to re-enter the head-unit code?
9th Dec 2011 1:55pm |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 |
I didn't need to reenter any codes on an '04. Some more info here |
9th Dec 2011 2:03pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 733 |
Thanks for all the info
9th Dec 2011 2:48pm |
I bought that very one a month ago,the best thing i have ever done. |
9th Dec 2011 3:13pm |
thats the best one john...
9th Dec 2011 3:18pm |
All fitted now - it's never spun over so fast
9th Dec 2011 4:21pm |
I thought you had to follow this proceedure to disconnect and reconnect the battery because of the pyrotechnic device in the battery +ve cable.
9th Dec 2011 4:29pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
A friend of mine once had a Seat Leon Cupra R which did the same thing, I think it was either an aux coolant or oil pump, something to do with the turbo IIRC, might be the same on the FFRR? 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
9th Dec 2011 4:51pm |
