![]() | Home > Technical > ABS, HDC Inactive, Air Susp Inactive - 2004 vogue |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 837
How's your battery? I know it may sound funny! But have the garage flattened your battery whilst doing the job and then bought up faults by either trying to start it without enough charge or worse still jump starting your car!
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8158
and if it is the battery and i concur with craig that it probably is, a good place to get a replacement is eurocarparts [110amp 920cca varta/bosch 020] and member t24res has just put up a discount code for 15% off [BATTERY15] ..............................
| the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 41
the battery was flattened. The car was off the road for about a week and i do believe it was jumped. Sorry for being naive but why the full lock of the wheel either way when jumping.
i had the same thing happen to me when my window tint man kept on running the windows up and down when he was applying the tints, dead battery and it was jumped normally but then all the lights happened..
When you first start the car after a battery disconnection you need to "lock to lock" the steering wheel as it lets the variable power steering know where the front wheels are and turns all the warning lights off on the dash ABS, TRACTION, AIR SUSP etc etc...
never EVER EVER! Got that, good to know! Jump leads are going in the bin lol |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
| Dolphinboy Member Since: 08 Dec 2009 Location: SW Posts: 332
I had exactly this last week adn lost all power when driving along! AA man came out and it turned out to be the battery Neg Pole and cable were not tight enough leading to intermittent power supply. Now nice and tight and running puurrrfick!! |
| bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 204
ive had the same message and traced it to a wheel speed sensor - £20 later fixed
| kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63
thats exactly what mine was - drivers side front ABS sensor cable rubbed through...unrealy the sequence of worrying lights it lit up LOL
| Gazellio @ Prestige Cars Site Sponsor Member Since: 22 Jan 2010 Location: SITE SPONSOR, Chilterns, UK Posts: 4072
Have to say I have jump started plenty (using the specific jump terminal) with no problems but may have been lucky I guess.... |
i think the correct way to jump the fullfat is to connect your spare battery/powerpack/charger and let it sit for a while so the fullfats battery gets some charge and the ecu's wake up gently and power up, then turn the key ... ..............................
Stan, your absolutely correct my friend...
