Home > Maintenance & Mods (L322) > Rear Wiper access - may be a daft question but...... |
Don't think so , thats your best option , turning off ====================================
12th Dec 2011 12:09pm |
swirl80 Member Since: 11 Dec 2011 Location: Northumberland Posts: 46 |
cheers mick, just wanted to make sure i wasn't missing a trick with a hidden button somewhere - still getting to grips with all the features it does have |
12th Dec 2011 12:15pm |
if you open the upper tailgate there are three 10mm bolts, thats all that hold the rear spoiler in place. Once out the spoiler slides off towards the rear of the car on two plastic slider bolts... 5 min job and gives you great access to clean and lube everything once a year... If you slide it off there is enough cable on the brake light to put the spoiler upside down on a towel on the roof...
13th Dec 2011 12:58am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
tuesday top tip! ... - .- -.
13th Dec 2011 9:12am |
13th Dec 2011 9:20am |
'top tip' entered into a new section in the wiki craig .. ... - .- -.
13th Dec 2011 9:47am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Hang on!
13th Dec 2011 11:16am |
your post is still on the wiki, its under ''rear wiper/washer motor removal''
13th Dec 2011 11:22am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
MOD FIIIIGHT!!!
13th Dec 2011 11:34am |
Oh goody
13th Dec 2011 2:04pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
^^^^^^ "Your bared!" [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
13th Dec 2011 2:26pm |
adam will win, he's got guns... ... - .- -.
13th Dec 2011 2:29pm |
Well seeing stan's got the bigger chest …. ====================================
