Home > Off Topic > SKY HD box problems
United Kingdom 2008 Range Rover TDV8 Vogue SE Auto Stornoway Grey
SKY HD box problems
Just wondered if anyone else has had the problems we are getting with our SKY + HD box and can shed any light on it.
When you select to go to the EPG, the box reacts as if you have pressed a button twice, so you see the EPG and then BANG! Straight into BBC1.
It seems to do this with all sorts of commands, like paging through the EPG it will do 2 pages in quick succession when you press the button on the remote once. If you go to play a recording it skips past the info screen and just starts playing.
We now have another new problem. Recordings are failing, and what seems to occur is that the channel you want to record shows as "No satellite signal is being received" however if you go up one channel then back down, the signal is fine and the programme is playing as normal.
It's driving me potty! Censored
I know that if I ring SKY they will want to send someone out with a callout fee and then say I need a new box at £250.
Any ideas from the collective? THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
http://www.fullfatrr.com/forum/topic666.ht...vented#end
2008MY TDV8 Vogue SE, Stornoway/Jet/Piano/ RSE+DVD
2003 Defender 90 TD5 Hard Top Ruggedised
*Gone: Range Rover Vogue TD6, JE Stage 1
*Gone: Range Rover Sport Supercharged 4.2V8
*Gone: Range Rover Vogue Classic 3.9 Auto
*Gone: Land Rover Series 3 SWB
Post #97654 14th Dec 2011 11:40am
United Kingdom 2005 Range Rover Td6 Vogue Auto Bonatti Grey
Have you tried powering the box off for a while? Also have you tried clearing it of dust with a hoover as they can overheat?
What type of box is it? Thomson or samsung?
I believe the most common issue is a power board failure and that these can be bought if you want to replace it yourself.
Personally i just take out a new 12month contract every year to get a new box and install to get it all checked over Smile
Post #97656 14th Dec 2011 11:46am
England 2005 Range Rover Td6 HSE Auto Cairns Blue
i would suggest a planner rebuild and new battery's [ Mr. Green ] in the remote..
planner rebuild http://www.sky.com/helpcentre/tv/sky-plus/...r-rebuild/ ..............................
this is handy Wink
Post #97657 14th Dec 2011 11:47am
googsy2
Ireland 2008 Range Rover TDV8 HSE Auto Java Black
Not sure have you tried reset by unplugging box ( sure you have but just checking)
I have a SKY HD box here if your stuck was about 6 months old when I switched to another provider Thumbs Up
Cheers
Googsy Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #97660 14th Dec 2011 11:48am
The power off thing is a regular occurence as it freezes up so often and the remote won't work.
Was just reading on the SKY Support site about the planner rebuild so may try that, trouble is it will wipe stuff off and the Wife will go MENTAL when Biggest Loser is not there...
there's no dust on it, it's very well ventilated and the remote batteries are new. We have two remotes and it happens with both, so it's an issue with the box. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #97664 14th Dec 2011 12:01pm
planner rebuild will not delete recordings adam...
quote ''Recordings in your planner will not be deleted'' ..............................
this is handy Wink
Post #97666 14th Dec 2011 12:12pm
Just tried the planner ebuild and it wont get to that menu! Censored
I get a message saying "menu not available while 2 recordings are in progress", but there are NO BLOODY RECORDINGS in progress.
Heap of Censored . THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #97667 14th Dec 2011 12:16pm
Power it off then as that could be the cause and its taking up processor time and slowing your box down and thus causing issues.
The top of the box may not look dusty but i bet the fan has been pulling dust inside it, hoovering right onto the vents should help relieve some of it as it acts as a blanket and kills electrical components Sad
Post #97668 14th Dec 2011 12:21pm
supershuttle
England 2007 Range Rover TDV8 Vogue Auto Rimini Red
Probably the bonnet catch Very Happy Geoff
2007 3.6 TDV8 Vogue
Rimini Red / Sand
Post #97702 14th Dec 2011 5:19pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
Laughing ..............................
this is handy Wink
Post #97703 14th Dec 2011 5:20pm
Site Sponsor
United Kingdom 2011 Range Rover Supercharged Autobiography Auto Atacama Sand
Have you tried a Virgin Box Whistle
We buy forum member cars - PM for a quote. http://www.garyelliott.co.uk/prestige_cars/
Post #97704 14th Dec 2011 5:32pm
2010 Range Rover TDV8 Vogue SE Auto Santorini Black
Just buy a sky HD box off gumtree or ebay for £30/40
Post #97712 14th Dec 2011 6:24pm
googsy2
£20 + postage from Uncle Googsy! Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #97762 14th Dec 2011 9:58pm
tboner001
United Kingdom 2011 Range Rover TDV8 Autobiography Auto Santorini Black
Just ring sky get a brand new HD box for £90 fitted by them and if you want to clone the planner thats easy to do takes 10 mins to open the box clone the drive and put it back in another 10 mins MY11.5 Range Rover 4.4 TDV8 Santorini / Ivory Fully Loaded Arrived March 1st Smile
Gone RRS TDV8 2010 Autobiography (with the proper engine)
Gone 2010 RRS TDV8 Mare Friday car Gone Rejected How can they send one out from the factory like this Sad
Gone RRS TDV8 HST MY09 Bullet proof monk Smile never missed a beat. Best looking RRS.
MY11 SDV6 Disco Time will tell.. Very Good so far
Post #97766 14th Dec 2011 10:24pm
