Home > Maintenance & Mods (L322) > SUNROOF CLOSING |
sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45 |
You might have something stuck in the sunroof channel and the range rover thinks that. You might need reset the sunroof do a search on here. Think you have to hold the sunroof button for a certain amount of time. |
15th Dec 2011 8:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
found using the search function.........
15th Dec 2011 9:18am |
If you keep your finger/pressure on the button when closing it should close OK. It may be something on the rails that is stopping it auto closing. Very common. |
15th Dec 2011 9:35am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
I've had this and there didn't seem to be one cure for it other than keep trying, try closing it without the one touch feature, by holding it forward.
15th Dec 2011 10:58am |
Lack of lubrication |
15th Dec 2011 11:12am |
Where is it lacking and what type?
15th Dec 2011 11:27am |
Moly grease would be too messy, a squirt of silicone spray on the runners should work |
15th Dec 2011 11:38am |
Brummy Member Since: 22 Nov 2011 Location: Sydney Posts: 5 |
Thanks everone for your suggestions.Its night time here now, and have now got it closed by using the tilt button,then the close button.
15th Dec 2011 11:55am |
The runners can also get slightly bent and no manner of spray grease or silicone will get the auto close to work. You may have to get used to manual finger closing |
15th Dec 2011 12:17pm |
