![]() | Home > Maintenance & Modifications > Door handle replacement |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 1477
hi, the first one may take that long but after that 15 to mins max.. i hope you did not pay no more then 40 for your handles.. V8 facelift Range Rover Autobiography 22" wheels.
| CarMan Member Since: 03 Dec 2011 Location: Cotswolds Posts: 58
Daveo - that's encouraging, apart from the bit about the cost of handles |
how much did you pay |
Bought off eBay for a good bit more than you suggested, so maybe I could also sell them on ebay and buy a new set for £40? |
they work out about 10 inc vat each with the cap and new pin and clip, you would get change out of 40 for a set of 4...if you are going to fit a set then fit a new set... V8 facelift Range Rover Autobiography 22" wheels.
What from a dealer? |
yes |
Confused |
have they priced the whole door handle as i can promise you they are around 40 a set, do you want to change the complete door handle or just the handle and cap V8 facelift Range Rover Autobiography 22" wheels.
Daveo, thanks for persisting with this - no definately just the external handles. You know, the bit that you pull and the paint falls off! The handles work perfectly and the surrounds behind were repainted by the dealer when we bought it. Part number on the boxes are all FRH 500010 but when I checked they said this was not the handle? I have a separate little box with the small keyless cover in. |
ok mate, looking at my invoice, 4x LRFH500010 @ £8.61 each,
Can't argue with that! Cheers |
heres the handle when removed, you can give the gasket a good clean at this point
| mrblonde Member Since: 24 Jan 2012 Location: Hertfordshire UK Posts: 102
A quick belated many thanks to Daveo as I was about to pay £70ish from ebay as well, but now I'll just get the covers you got.... Does the door card need to come off to chage the covers? |
