![]() | Home > Technical > Heated screen only half working |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 367
I think the elements or 'lines' within the screen break and stop heating up. At least the drivers side still work at the moment |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
Find a stone chip, call your ins co. Say the chip is stopping the heated screen from working. They will replace the screen for the £50-£70... The lady I spoke to said they always recommend replacement screens on heated screen vehicles rather than resin injection. |
| bigl322 Member Since: 15 Apr 2009 Location: central belt Posts: 367
is there 2 fuses for the heated screen ? normally heated screens are 2 seperate circuits |
| CarMan Member Since: 03 Dec 2011 Location: Cotswolds Posts: 58
Apparently there are 2 fuses but just a few strands on the left are working plus all the right side so it's not that. Booked it into my local dealer before Christmas and they tell me it needs replacing but it's not covered under warranty. Cost is nearly £700 so I phoned the supplying dealer who very helpfully suggested I call LR warranty, who advise me it is covered. How does that happen! Anyway, the news is more positive. |
In case it helps anyone else - although glass is excluded from the LR extended/used warranty it is an electrical fault with the windscreen itself and therefore covered. My local independant dealer has now been authorised to replace tomorrow I understand |
| alanm_3 Member Since: 19 Feb 2011 Location: Glasgow Posts: 1306
I used mine the other day for the first time, and sod's law says it's the drivers half the doesn't clear, so can anyone point me towards which fuses the screen uses? Got - 2008 TDV8 Vogue SE in Java black
| Joe90 Member Since: 29 Apr 2010 Location: Winchester Posts: 1072
Handbook indicates only one fuse No. 47 (30amp) up front. |
That'll be that then! |
I am certainly no expert but I have been told by two dealers that the screen has 2 fuses |
There is also mention of the relay:
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 347
Mine clears on the left, and a couple of narrow bands in the middle, but the drivers side doesn't work |
| Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 84
Hi
| noddy Member Since: 24 Feb 2009 Location: Birmingham Posts: 1125
Mine doesn't work on the drivers side either. Strange. 02 Vogue |
