Home > Maintenance & Modifications > Just won on ebay
Kads
England 2005 Range Rover Td6 Vogue SE Auto Java Black
Just won on ebay
Hi all,
Just won a set of L322 brembo calipers and pads.
What other items do i require to upgrade my front brakes.
What discs?
What brake lines?
etc?
many thanks Kads
Post #98915 22nd Dec 2011 5:49pm
PaulB
2005 Range Rover Td6 Vogue Auto Bonatti Grey
I might be wrong, but I think you have to have the right size wheels as well
Post #98917 22nd Dec 2011 5:51pm
Kads
sorry got 22 inch overfinch on mine, so thats not an issue. Kads
Post #98919 22nd Dec 2011 5:51pm
daveo
United Kingdom 2004 Range Rover 4.4 V8 Autobiography Auto Java Black
hi was it the chap that had 2 sets with buy now Shocked new with pads but scratched fron being stored...... V8 facelift Range Rover Autobiography 22" wheels.
Post #98920 22nd Dec 2011 5:52pm
Kads
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...CA:GB:1123
link attached
he didnt have much of a description? but it did state L322 Kads
Post #98924 22nd Dec 2011 5:58pm
daveo
hi not the ones i was thinking of, you will need the 344mm disc, i think thats the size but they will or should be listed as for brembo's as they are bigger then standard, if you go for new disc then you must put a new set of pads. the pads come up on ebay some times for around £40 and the sensor around a tenner. you will need new flexi brake pipes as well. now for the hard bit.
you will need to cut the backing plate/splash shield so it will clear the caliper.
http://www.ebay.co.uk/itm/SFP500070-RANGE-...396wt_1112
http://www.ebay.co.uk/itm/RANGE-ROVER-3-0T...397wt_1112
http://www.ebay.co.uk/itm/SDB500193-RANGE-...376wt_1112
http://www.ebay.co.uk/itm/SEM500090-RANGE-...394wt_1112 V8 facelift Range Rover Autobiography 22" wheels.
Post #98927 22nd Dec 2011 6:07pm
