Home > Technical > Groaning noise from nearside front after starting
Olders
United Kingdom 2007 Range Rover TDV8 Vogue SE Auto Tonga Green
Hi all,
Happy New Year to you!
Just wondering if anybody might be able to help identify a strange noise that I have started hearing over the past few weeks...
It is an intermittent (2/3 secs on, 4/5 secs off) groaning sound that lasts for about 30 secs and normally occurs within the first 1 or 2 minutes or so after the engine has been started, it comes from the front passenger side of the engine bay, right by the side vent. It goes away permanently (until the engine has been switched off and re-started) within 3 or 4 minutes of starting. It happens whether the car is stationary or driving, so doesn't sound like it is braking or drivetrain related. Whilst I can't swear to it, I think it mainly happens when starting the car from cold (it certainly happens every time the car is started from cold, perhaps not every time when warm - i.e. after stopping for fuel or something).
Whilst annoying, it is not totally un-livable with, but I would like to identify it in case it is a precursor to another problem (and to try and stop it happening)!
Searching through the forum, I have found posts suggesting that the FBH can make similar noises to this, however I am not convinced as:
1) I have not used the FBH since acquiring the car and as far as I am concerned it is switched off and
2) I thought that the FBH only works when the engine is switched off - this noise only occurs shortly after starting.
Any thoughts much appreciated!
Many thanks in advance! Thumbs Up -----------------------------------------------
2007MY FFRR Vogue SE TDV8 Tonga Green
Post #100254 4th Jan 2012 12:53pm
Johnte
United Kingdom 2005 Range Rover Td6 Vogue Auto Tonga Green
Interesting, as I have exactly the same symptoms Sad
But as I understand it, the FBH does come on automatically below a certain temp as soon as the engine is started, to help it reach operating temperature quicker - and doesn't need to be turned on manually.
So, perhaps the problem could be FBH related.. Confused
Post #100256 4th Jan 2012 1:08pm
Olders
Hmmmm... interesting....
Do we know if that is a normal sound for the FBH or if it is a sign that it isn't working properly? -----------------------------------------------
Post #100258 4th Jan 2012 1:33pm
Johnte
I'm guessing it should be virtually silent .. Sad
Do you have the heater blower on at the time? I turned mine off last time and it made the noise disappear, it may be just coincidence.
Post #100260 4th Jan 2012 1:51pm
United Kingdom 2005 Range Rover Td6 Vogue Auto Bonatti Grey
It will kind of groan on initial startup but then settle down to more of a mini jet engine sound Smile
Post #100263 4th Jan 2012 2:11pm
googsy2
Ireland 2008 Range Rover TDV8 HSE Auto Java Black
Its not the heater is it ? mine makes a farting noise when I switch on the car although it farts and groans after I switch the car off too its always done this which leads me to thinking it aint anything serious. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #100264 4th Jan 2012 2:11pm
simon1233
United Kingdom 2007 Range Rover TDV8 Vogue Auto Java Black
Sounds like the FBH starting up to me, as Kingpleb has said it quietens down after it has been running for a few minutes. The FBH comes on automatically once the temperature is below 6 degrees (IIRC) to assist with heating the cabin. Thumbs Up
If you want to make sure that the heater is running then check the exhaust pipe which to the rear of the front passenger wheel well, if you put your car into off-road height and then have a quick look underneath you can see the pipe coming down out of the engine bay (behind the plastic liner), put your hand near to the end of it and you should be able to feel the exhaust gases
Post #100270 4th Jan 2012 3:21pm
PaulB
My FBH makes the same groaning noise.
Post #100280 4th Jan 2012 4:50pm
killatomato
United Kingdom 2005 Range Rover Td6 Vogue Auto Java Black
Yep, mine does that too. But my local garage thinks its the air con on its way out! It does sound silly coming from such a prestige car especially outside the school. Embarassed
Post #100292 4th Jan 2012 5:17pm
Mikeyjd
Wales 2003 Range Rover Td6 SE Auto Zambezi Silver
I think you may be confusing a couple of uses of the fbh. It is fitted to all diesel FF's as a quicker means of warming up the car in the colder weather. A secondary use (which is not standard on all models) is for it to come on in advance as a cabin heater when the car is parked up. Mine has the basic fitment and like yours over the last few weeks in the colder weather the car makes the strange "groaning noise" when I start it up. Pretty sure that is what you are hearing. As far as I am aware you cannot turn off this basic feature, although I could be wrong of course. Td6 SE
Previous LR- Disco 300TDi Auto
Post #100333 4th Jan 2012 10:49pm
landyash
I Olders I have just joined today, Hello all.
It sounds like you pre heater I think it only works
when it's cold,mine does the same and goes off after its warmed up.
It's located under passenger wing.
hope this helps
Ash.
Post #100371 5th Jan 2012 11:21am
Johnte
Good - sounds like it's the 'normal' noise then ... Thumbs Up Thumbs Up
Post #100373 5th Jan 2012 11:30am
comports
United Kingdom 2004 Range Rover Td6 Vogue Auto Java Black
Mine sounds like an angry bee for a few minutes! Ashley
2004 TD6 Vogue - Black with Sand
2010 KUGA 2.0 AWD
2003 CLK 320 Cab
Post #100457 5th Jan 2012 8:35pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
happymadison1978
2006 Range Rover Supercharged Vogue SE Auto Zambezi Silver
Groaning mumbling, farting- has the wife eaten any Jerusalem Artichokes?
Just kidding a friend of mine has an 08 TDV8 and his FBH sometimes sounds possessed.
Post #100469 5th Jan 2012 11:03pm
Olders
Sounds like it is the FBH and is relatively 'normal'.
Thanks for all feedback and advice everybody; very kind! Thumbs Up
Great to have all your collective knowledge so freely given! Cheers! Bow down -----------------------------------------------
Post #100821 8th Jan 2012 8:39pm
