Home > General > L322 Newbie Needing Purchase Advice, Please
Sorry chaps, but I don't yet own a Range Rover.
However, I have a rather large desire to own an L322 4.4 Vogue. This has replaced my desire to own a P38 as I realised the P38 was an attempt to be relatively sane with the purchase price. But the L322 makes more sense to me as a daily car on my current 30 mile round trip to work.
Much searching has netted a shortlist all hovering around the £11,000 mark and the 85,000 mile (with full LR history) area.
The one that particularly grabs my eye has been LR serviced only recently and looks glorious in exactly the outside and inside colour combination I want.
Before I take wife and the little people off to view, may I ask whether this mileage spells iminent gearbox failure? I'm well aware of their 'sealed' nature and should I purchase this particular one, I'd get the 'box emptied, flushed and re-filled and filtered.
I'm assured it drives seamlessly, but I'll be the judge of that.
And anything else I should be especially vigilant for?
Sorry if this is an oft-repeated question. I have looked and amassed some very useful information here, but can't really find anything that prevents me asking. I'm sure I've missed it. Si. <This is my name.
Post #101150 11th Jan 2012 1:47pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Hi there,
You're right to focus on the gearbox, I'd say make sure you get a 3 month warranty, get the gearbox flushed as soon as you get it. Before you buy, ensure that flushing the gearbox won't invalidate any warranty, possibly try to get the dealer to flush the gearbox oil before you buy.
Check all of the electrics, every single thing. Check the suspension goes up and down as it should check the low ratio gearbox. Other than than, as with any other car. Good luck with it! Thumbs Up 2012 SDV8 Vogue SE
Post #101151 11th Jan 2012 2:01pm
M44K TS
85k on a petrol V8, the 'box should be fine. A fluid flush is a good idea like you mention. Check to see if it's had the front diff recall done as that could be a bargaining tool. Do a search on here for diff recall for all the info.
Other than that, check everything electrical works, especially things like the air suspension, make sure it goes through all of the height setting quickly and smoothly. Check the low range works, as occasionally, they can seize up with lack of use, (select neutral, then flick the low range switch on the centre console, you should hear the actuator then get the confirmation on the dash that it's in low range) Take a couple of allen keys with you, whip off the plastic engine cover, (4 1/4 turn bolts IIRC) and feel for soggy/damaged rubber pipes for the oil breather system at the back of the engine next to the bulkhead as they can split, again, all the info about the PCV breathers are on here if you do a search. Listen for any ticking when starting from cold for the first few seconds, could be a sign that the vanos unit needs looking at, common BMW issue, plenty of info on the 'net about it.
Body wise, open the back doors and check for rust at the bottom edge of the wheel arch lips where they meet the door aperture , they can bubble up there. Open the compartments in the boot and check for any signs of dampness/water ingress, especially in the n/s compartment that houses all of the radio/nav/dsp units etc. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #101152 11th Jan 2012 2:06pm
jaybear
France
Don't get frightened by the gearbox so much on the petrol one . Do as Bozman advise , ie the Flush , but FYG , the actual big issue with Gearboxes is with the GM box for the TD6 .
Jaybear Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #101153 11th Jan 2012 2:07pm
Bow down
Bang on!
Thanks. Thumbs Up There's one other Vogue that's had a 'box replacement at 94,000 miles. Actually, there's two reasonably local to me. And another that's had an engine replaced at 100k (stone hit the rad and lunched the engine) which looks stunning at a nearby specialist.
But this one and the dealer's approach to me has really got me fired up. No sales patter and he walked round the RR on the phone and answered every question I had.
I'm a fairly competent DIY mechanic (had to learn with a Series, Defender and an old Discovery) and can enlist excellent help when the need arises to keep mechanical costs down. But I don't want a gearbox or engine failure and am a very firm believer in preventative maintenance.
If there's any further nuggets, I'd be really grateful. Si. <This is my name.
Post #101154 11th Jan 2012 2:17pm
Go in the boot and pull off the side access panel on the passenger side and check for signs of water ingress and electrical components wet and suffering corroded connectors. Can be very costly to remedy and generally a b Censored y nuisance that will only get worse thro time.
Post #101165 11th Jan 2012 3:12pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
[quote="M44K TS"] Listen for any ticking when starting from cold for the first few seconds, could be a sign that the vanos unit needs looking at, common BMW issue, plenty of info on the 'net about it.
quote]
Hi Mark,
Is that really correct, I am sure I have came across a few threads with people asking about this and its not something to generally worry about, I used to have an e36 M3 which obc had the vanous units and that made a noise over 50,000 miles but never once had an issue with it at all. They do have a unique sound and especially from cold for the first 2-3 seconds.
Just my 2 pence. I wouldnt let it put me off buying a car unless it sounds like a tin of nails.
Post #101184 11th Jan 2012 5:04pm
M44K TS
&Yeah, you're quite right, it's nothing to really worry about, mine used to do it from cold for a second or so, doesn't affect anything but just thought it could be a good bargaining tool. 2006 Mercedes CLS
Post #101186 11th Jan 2012 5:23pm
RR8701
Post #101190 11th Jan 2012 6:22pm
EVOeng
Have you had a look at mine?
Less miles and open to offers...
http://www.fullfatrr.com/forum/post98298.html
Not far from you either.
Post #101191 11th Jan 2012 6:23pm
Very nice, Ram! Thumbs Up
Could you please confirm the current price as it was originally up for £12,500 and then 'reduced' to £13,500.
I've planning to view 3 Vogues over the next few days. Could you please PM me your approximate location?
And thanks again for more of your excellent replies! Si. <This is my name.
Post #101223 11th Jan 2012 8:27pm
Bargain of the week, now further reduced to £15,000 Thumbs Up
Post #101226 11th Jan 2012 8:43pm
http://www.fullfatrr.com/forum/topic9348.html Smile .
Post #101239 11th Jan 2012 9:28pm
EVOeng
Just to confirm, the price is £12500, it was reduced to this amount from £13500 - however I just have not removed my post. (All done now though)
Post #101255 11th Jan 2012 11:00pm
Well chaps. Thanks to your excellent advice, and a few conversations with Ram (Evo...), I piled wife and the two orphans into our E55 and headed to Ram Towers in Londonshire.
This was after looking at a few other Vogues and calling and discussing countless others.
Ram's Vogue stood out from the others I'd shown interest in. It's very nice indeed!
So it didn't take me long to decide to buy it. Funds are yet to exchange, but the details are agreed.
If all goes according to plan, I'll have the keys next weekend. Si. <This is my name.
Post #101712 14th Jan 2012 5:51pm
