![]() | Home > Technical (L322) > Lumbar Pump replacement |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
If you need one I have one used but working fine |
Sorry seat out its easy to remove |
As soon as I get mine out and test it, I will let you know whether it is the pump or something else. Thanks for the offer, will definitely use it if needed |
Do you need to take the seat back off or can you get to it from the bottom of the seat ?? MY 2010 5.0 SC Galway green and sand interior!!
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Can you hear nothing when you operate the button? The two times I've had a problem it's just been the pipe come off! 2012 SDV8 Vogue SE |
No sound whatsoever, the passenger seat you can hear it. Already checked/cleaned the switch but not a peep. Need to check power to the switch though to be sure. MY 2010 5.0 SC Galway green and sand interior!!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Take the seats rear lower cover off (two torxs on the bottom) and pull the back up and off, then remove the two clips that hold the leather cover over the metal frame at the bottom and you get to a valve type mechanism for the lumber control... I bet you its unplugged itself... Have done this to a dozen FF's so far...
Thanks Craig, will have a look asap and hope you are right |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
Hello, if you have the standard seats you have to remove the plastic shell,
Update time. It is not working (yet ?).
