![]() | Home > Technical > Strange temperature gauge |
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 88 |
I dont think a thermostat is that expensive, around £30-£40 from a quick google search. its basically just a valve with a wax block in, when the wax block melts the valve opens. will need to replace coolant also.
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8158
dan [duckworths] is the best place to get the thermostat and you'll need fresh coolant as well. ..............................
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 980
£38inc vat for genuine
I would think if the pump fails or thermostat stays shut the temp would raise above a safe level.
| Joe90 Member Since: 29 Apr 2010 Location: Winchester Posts: 1072
Ignore the V8 stuff, that's a walk in the park compared to the TD6 |
| Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 84
What you say joe
http://www.fullfatrr.com/forum/post94803.html?#94803
| NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 83
My SC has the same issue with the temp gauge. When we had the cold spell the other day the temp gauge barely got off the blue on a 40 mile journey and I wasn't getting any hot air through into the cabin. Time to investigate I think. |
| JOKER Member Since: 11 Sep 2008 Location: Here Posts: 7749
It's a new thermostat she needs Nick , I was going to get it done before I traded her in , reason for not doing so
| stenh02 Member Since: 30 Jan 2011 Location: Up North Posts: 54
Is the access easier on the S/C? I, too, have the swinging temp issue!
