Home > Wheels & Tyres > tyre size - will 275/55/20 fit |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
shouldnt rub but your speedo will be out
26th Jan 2012 5:55pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
probably a better ride over the 50 profile too. Present :2008 TDV8 HSE
26th Jan 2012 5:58pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1239 |
Yes, they'll probably fit provided that they aren't an oversized 275/55 ... just like shoes, some makes are bigger than others even when labelled as the same size.
26th Jan 2012 8:33pm |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
I have just fitted a set of Nitto Terra Grappler G2's (275 55 20's) to my 04' L322 and they are a 'big' shift from the 265 50 20 road tyres I had on when I bought the car. They are already scrubbing, where you stated, around where the fuel filler goes down but I'm more worried about the wheel arch, especially on the drivers side. the steel spot welded seam at top dead center of the arch is cutting into the side of the tyre tread when I turn left and hit a dip in the road at speed. I am thinking of trimming this seam and tapering it back towards factory standard over a 6 inch length. I'll have to grind the plastic back too. What do u think?
6th Nov 2018 8:41am |
