Home > General > possible issue
supermario
possible issue
Hey guys,
Just a quick question noticed this on Friday (smell - temp around -1 up here if that makes any issue) evening but was away over weekend so did not get to drive car until this morning. Car is driving fine but when I pulled up into the car park, opened window down to put pass into barrier noticed a slight creaking sound as the car was driving up the two floors got out could smell a burning smell - got out the car the smell is not too smelly on the outside fairly subtle but there. Had a quick look at forums on Sat checked all the wheels today and noticed significantly more heat coming from the rear right wheel. Could it be a stuck caliper - car is not pulling to one side I don't think and seems to be coming to a stop and coasting normally. Im going to do more of a thorough check at lunch anything to look out for? its a 56/2007 SE?
thanks in advance.
Post #104335 30th Jan 2012 11:02am
ebajema
Hi mate, sounds like the sticking caliper problem. Several of the S/C owners (including myself) have had it, have a look in the recent posts/search. The rear brake calipers seem prone to it. I have had both rear calipers replaced (cost of calipers about 70 Euro each), labor here is cheap.
There are several posts on this issue. Suggest to go to your local dealer/indy to check and change out quickly. Also get the brake fluid changes maybe. If you are handy, you can easily do it yourself (I did heaps of them on the old junkers that I used to drive but don't have tools nor time here ;().
Most cars don't pull and the issue gets worse when driving longer (did on mine) and it started "juddering" a bit (as the brake was grabbing more/less/more/less).
Good luck and keep us posted on the outcome. 2006 Range Rover Supercharged, Zambezi silver, black laquer/jet interior and all options.
Post #104336 30th Jan 2012 11:10am
supermario
Thanks for the quick reply - going to get it looked at tommorrow. Loving your prices though!
Post #104346 30th Jan 2012 11:52am
rich_959
United Kingdom 2007 Range Rover TDV8 Vogue Auto Stornoway Grey
Supermario - I posted a thread last week. Had my rear drivers side caliper replaced on Friday at an independant specialist. £75 plus vat for the caliper and £50 labour.
Post #104368 30th Jan 2012 2:36pm
supermario
Thanks Rich. I checked it at lunch only did a 1 mile drive and now it seems fine no burning smell - maybe needs a longer drive? Ill check again when I go home thats a 4 mile drive. If it does seem fine should i bother getting fixed or will it happen again possibly in the future?
Post #104371 30th Jan 2012 3:32pm
Olders
United Kingdom 2007 Range Rover TDV8 Vogue SE Auto Tonga Green
Had 'extra heat' and intermittent gentle squealing sound from offside rear a couple of months ago.
Definitely sticking calliper. Had it changed at an Independent immediately before it did too much damage to the disc. Cost was about the same as Rich_959. Car had done about 65k and is also a 56/2007 MY. Guess it is just about old enough now for these things to be expected!
Wouldn't hang around too long before sorting it out though, even if it is intermittent; no point adding new disc and pads to the bill!! -----------------------------------------------
2007MY FFRR Vogue SE TDV8 Tonga Green
Post #104492 31st Jan 2012 12:25am
supermario
Thanks guys. Took it to the dealers they are reccommending pad change although they said they are fine!
Post #104528 31st Jan 2012 11:01am
Scotland 2002 Range Rover Td6 SE Auto Oslo Blue
How does pad change stop the caliper sticking?
Post #104530 31st Jan 2012 11:04am
Olders
Agree with47p2. Can't see why putting new pads on is going to cure a sticking calliper!
Perhaps taking the old ones out, giving everything a clear out and then re-fitting, but can't see why new pads are needed.
Confused -----------------------------------------------
Post #104533 31st Jan 2012 11:13am
Once the caliper starts sticking it will progressively get worse.
Best change the caliper and that's the job done.
Or maybe the dealer is thinking of his profits, change pads, ££, change caliper £££ Shocked
Post #104534 31st Jan 2012 11:16am
supermario
Sorry should of said do a caliper change and recommend a pad change. Said teh pads seem fine but they have been heating up bad and could have cracks
Post #104542 31st Jan 2012 12:06pm
Yes I agree with that Thumbs Up
Post #104545 31st Jan 2012 12:21pm
supermario
Its what I call a B class bug.
A Class - Car needs fixing asap does not work
B Class - Car needs attention drives but should be fixed sharpish
C Class - minor-ish issue - car still works fine though such as my alarm bonnet switch
D Class - shut up thats not an issue - my CD player not working but on a restart being fine.
Sorry i'm being pedantic now and voicing my inner workings.
Post #104550 31st Jan 2012 12:53pm
supermario
These dont look like new brake discs do they? Apparently just changed
http://www.fullfatrr.com/gallery/displayim...;pos=-4241
http://www.fullfatrr.com/gallery/displayim...;pos=-4242
Post #105018 2nd Feb 2012 5:28pm
Difficult to say from the pictures, try running your finger tip over the shiny surface and off the outer edge and feel for a slight lip at the edge
Post #105027 2nd Feb 2012 6:11pm
