Home > Maintenance & Modifications > Which antifreeze?
MrP
England 2003 Range Rover 4.4 V8 Vogue Auto Stornoway Grey
Which antifreeze?
I need to top up the antifreeze and don't know what type to use. L322 '53 plate vogue. Serviced by LR so need to make sure I add the same stuff. Don't want to mix it up.
Thanks
Simon "On first name terms with my local Dealer......now."
'53 plate 4.4V8 Vogue Bonatti Grey inside and out.
Post #104538 31st Jan 2012 11:42am
England 2005 Range Rover Td6 HSE Auto Cairns Blue
on the wiki simon under 'recommended lubricants' ..............................
this is handy Wink
Post #104539 31st Jan 2012 11:55am
MrP
Going to hate myself for asking this - halfords alternatives?...... Crying or Very sad "On first name terms with my local Dealer......now."
Post #104629 31st Jan 2012 5:55pm
dont know, but i'm sure if you go in there with the specs from the wiki they will be able to find something compatible.. ..............................
this is handy Wink
Post #104638 31st Jan 2012 6:52pm
bjs
United Kingdom 2003 Range Rover 4.4 V8 Vogue Auto Java Black
Undo the bleed at the bottom of the rad (in corner N/S facing engine) just a little bit and with a white rag in place you will soon see if it's blue or pink... (be careful not to get on you...)
If it's LR serviced I would put money on it being Blue...
Best to be sure though, do not mix.... as for Halfords..... About £30 ish from main dealer, give the girl what she knows to work !!! cheaper in the long run Rolling Eyes
Post #104961 2nd Feb 2012 1:52pm
