Home > General > Would LR diagnostic software be able to locate a drain?
mrblonde
2003 Range Rover Td6 Vogue Auto Adriatic Blue
VaguelyVogue wrote:
a) I haven't seen a red flashing alarm light by the rear view mirror (although the light may have changed position with model year)
b) The standard advice is to get the battery checked - the RR uses a lot of current and batteries rarely last 5 years
c) You haven't got a non factory fit immobiliser/ alarm have you (may relate to point a above) - this may be isolating the starter motor ?
d) When you get to the point of all the dashboard lights coming on - do all the lights go out when you turn the ignition key to position 2 or do they just dim ?
Cheers VV
b) Will any garage do the battery check? Or do i need to see an auto-electrician? What test do i ask for?
c) no extra alarm or immobiliser fitted
d) Tried again today to answer your question but all was completely dead, not even any lights or remote locking working Sad so cant answer im afraid. Im sure when i tried it few days ago though, all dash lights lit up, turned key nothing, all lights remained on and full brightness, just nothing in way of turning over, didnt even attempt to try turning over
Hope this helps a bit
cheers again
Post #104867 1st Feb 2012 7:30pm
England 2004 Range Rover Td6 Vogue Auto Giverny Green
The battery's flat.
Post #104873 1st Feb 2012 8:34pm
England 2002 Range Rover Td6 HSE Auto Alveston Red
scarey wrote:
go back 7 posts joe Wink
I simply copied and pasted the link Twisted Evil
Have "RSW All Comms" in Hampshire - happy to help Smile
Current Combustion Engine Transports:
Range Rover 2002 TD6 HSE Alveston Red, Sand Leather
Audi 2004 Cabriolet Sport 3.0 (Amulet Red)
Mazda Eunos 1990 (Brilliant Red)
MG Midget Mk 1 1962 (undergoing restoration) (to be Nightfire Red)
Post #104875 1st Feb 2012 8:58pm
Mr Tee
Scotland 2002 Range Rover Td6 HSE Auto Java Black
I have had the very same issue, sometimes the car would be ok for a few months then a few weeks then a few days etc. Got the FSR changed over and calm has been restored (until the fuel pump went this week and then currently in having the brake pipes done, joy!) I doubt the FSR would be a warranty claim unless the car is newish, I would get this done before replacing the battery.
Post #105021 2nd Feb 2012 5:38pm
mrblonde
Mr T I'm sure mine had the fsr done before I got it, is there a simple way to check?
Post #105029 2nd Feb 2012 6:16pm
Mr Tee
Without taking the part out, maybe contact Dan @ Duckworths if the repair was done by Landrover dealer network. Alternatively, removal of the part is the only way!
Post #105215 3rd Feb 2012 1:35pm
