Home > Maintenance & Mods (L322) > BMW Upgrades
Page 2 of 3 <123>
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
So looking at my 3 series BMW sitting in the garage next to my FFRR - I can see a transplant session happening - first aid kit and under seat storage box and the under seat fire extinguisher.
Very Happy "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #107838 17th Feb 2012 6:19pm
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Hi, just wondering, I have a 02 vogue, with the phone in the arm rest,
I have found a 3rd gen ulf, will this allow me to connect my iPhone? Or should I get a newer one? Found a 7th gen aswell, but a lot more money
Cheers Toby
Post #134361 4th Aug 2012 9:23pm
MrP
It may work yes but the later the generation typically the better connectivity and features. I have the latest gen 13 and all works well but as you have noticed they are not cheap. "On first name terms with my local Dealer......now."
Post #134365 4th Aug 2012 9:58pm
Deasy
That's great cheers, lol no they arnt
The 3rd gen is at £30
And the 7th is £110 inc postage, but this is also MIT SES So the voice control should work aswell? So I gather?
Post #134368 4th Aug 2012 10:02pm
mjdronfield
I have a 6th gen I think. (car at bodyshop so can't double check) can't help with iphone, but it does have voice control on it, so you can use that button on the steering wheel also.......
Earlier ULF's don't have that feature.....
If the unit says ULF mit SES on the label it means it has voice control.
Just in case that's any use if you decide not to remortgage for the 13th gen !!
I seem to remember a thread on here where there was a problem with an apple OS version causing connection issues at some point, rather than the ULF's..........
You've obviously done some research, so I assume you know you'll have to do some rewiring on the car and that you'll also need a bluetooth antenna........
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #134427 5th Aug 2012 9:58am
Deasy
Thanks for the reply mark,
The the 3rd gen I have found sais it is MIT SES, but all in I'm not overly botherd about VR anyways
Yes I'm aware of needing to repin the plug, although I'm struggling to find a pin guide, I know there is one out the as I have seen it, I'm just struggling to find it again
Didn't know I needed a Bluetooth antenna, do I need a specific one?
Thanks
Post #134434 5th Aug 2012 10:55am
Deasy
Right, antenna found, but none of them come with the cable, that seems a little more difficult to get hold of
Loads of them in America, might try BMW direct on Monday, unless thers anywhere else to get one from?
Post #134437 5th Aug 2012 11:09am
mjdronfield
I've already done the ULF upgrade.
PM me your email and I'll send you the chart I used for the rewire.
Also get a new plug from an Audi dealer, which I posted somewhere else, as it will make the rewire much easier. You just move the pins you need to the correct place on the new plug, and leave all the old ones on the old connector. Then just connect the new one to the ULF.
Let me know if you need more info.
There should be 2 "bolts" sticking up from the frame that holds the sat nav. the antenna fastens on there..........
My car was prewired for phone, so the cable was there in the boot already.
Not sure how things change if you have the phone in already.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #134450 5th Aug 2012 12:47pm
mjdronfield
Not 100% sure, but will this not work for the cable ?
http://www.ebay.co.uk/itm/BMW-E85-Z4-car-t...2a177f58e6
Does your existing setup already have a cable ?
I may have part number for mine somewhere....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #134451 5th Aug 2012 12:55pm
Deasy
That's great cheers, pm on its way
Il check when I get it back from the garage, It currently has water pump failure issues, 2 pumps in a week Surprised
Post #134465 5th Aug 2012 1:42pm
Deasy
Thanks mark for your help,
All bits on order and on the way
Managed to get a 3rd gen ulf for £45, the bloke said it was MIT SES so should have voice co trol but not really bothered if not
Bluetooth receiver for £15
And a Ariel lead for £12
Will let you know how I get on Very Happy
Post #134849 7th Aug 2012 9:19pm
Deasy
Wow, mark, you never said it was so easy to do Very Happy
So, I repinned the socket, plugged it in and it worked, spot on
All for £60, I didn't need the cable in the end, so I will send it back or sell it
Didn't change the mic, it seems fine, but I might upgrade that at some point
Cheers Very Happy very happy now
Post #135791 13th Aug 2012 10:40pm
mjdronfield
Excellent.
I think it's well worth going the ULF way.
How did you do the pairing button ?
Did you get the new socket from Audi, or did you just re-pin the existing one ?
I was a bit unsure about all the wires that were not used in the existing one still being connected up, so thought if they were in a plug of their own, it would be the safer option.
Having done it, I'd say sourcing a decent ULF at a good price is the hardest bit.
Pleased you are happy.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #135826 14th Aug 2012 9:40am
Deasy
I had been looking for a long time at doing it, but the bimmernav cost of $700 without a ulf was putting me off!
I didn't get a Audi plug, as me nearest Audi dealer is abit of a trek away, I'm prety good with wires, being a sparky n all that, so I just labeled everything up and repinned the existing, all unused ones I just individually heat shrinked the ends so they are safe
There are a few 1st gen ulfs on eBay for £80 - £100
So I think I did prety well getting a 3rd gen for 45 delivered Very Happy
With the pairing button, I used piggy back connectors on 32 and 36 with flying leads to a connector block, and then just shorted out as required, I didn't see the point in running a proper button for the amount it will get used
Post #135830 14th Aug 2012 9:50am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
Where did you get your ULF from for that price?!? l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #135832 14th Aug 2012 10:39am
Page 2 of 3 <123>
