Home > Technical > CTEK hard wire kits
Page 2 of 4 <1234>
nbunney
I would say thicker than the connector being 12v Thumbs Up
Post #106161 8th Feb 2012 9:06pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
SparkyPhil
England 2005 Range Rover 4.4 V8 Vogue Auto Adriatic Blue
right if you use 1mm squared multicore 70 degree thermoplastic insulated and sheathed cable
you should get a volt drop of 0.35 volts over 20m assuming you are pulling 0.4amps from the charger this should be acceptable as it is less than 4%. on low voltage supplies(up to 1000v) its 3% lighting and 5% other,but to be honest I dont know what volt drop is allowed on an extra low voltage(12v)
phil
ps I went to the van
Post #106162 8th Feb 2012 9:14pm
England 2004 Range Rover Td6 Vogue Auto Giverny Green
What happens when the battery is down a bit and you are pulling 6A on the dc side?
Post #106163 8th Feb 2012 9:21pm
SparkyPhil
assuming all the other figures are the same then the volt drop would be 5.28v.
Phil
Post #106164 8th Feb 2012 9:27pm
Therefore as the max voltage output of the charger and most chargers is 14.4V the supplied voltage to the battery would be 9.12V.
This would mean the battery wouldn't charge.
Back to plan B.
Post #106166 8th Feb 2012 9:29pm
SparkyPhil
to pull 6amp on a 12v system over 20 metres you would need a csa of 16mm squared Shocked now that would leave a dent in your door seals Laughing
Phil
Post #106167 8th Feb 2012 9:44pm
Scotland 2002 Range Rover Td6 SE Auto Oslo Blue
Is the 40m distance within your own property?
Post #106170 8th Feb 2012 9:47pm
supershuttle
England 2007 Range Rover TDV8 Vogue Auto Rimini Red
Cut the clips off leaving sufficient length and buy some 4mm "banana" inline plugs and sockets to fit and do the same with the ctek accessories or fit sockets on the charger.
Just an idea Very Happy Geoff
2007 3.6 TDV8 Vogue
Rimini Red / Sand
Post #106212 9th Feb 2012 12:55am
mrblonde
2003 Range Rover Td6 Vogue Auto Adriatic Blue
Gents
What do you think of the CTEK lead with the battery level display in line? Its got traffic light indicators at to battery health, and then the waterproof plug to plug a CTEK into under the bonnet?
Post #106750 11th Feb 2012 8:18am
mrblonde
Gents
Ive fitted a new battery, and a CTEK easy charging plug with status indicator, connected to the battery with the eyelets its fitted with. I now need one of the CTEK male plugs that go into the female charging port, any ideas where I can get one? Apart from with a CTEK charger?
Cheers in advance
Post #107590 16th Feb 2012 3:36am
United Kingdom 2006 Range Rover Supercharged Vogue SE Auto Bonatti Grey
I have wired one into my car with a cheap lawnmower type plug on the mains power under the bonnet in a dry area, when i want to charge the car or leave for a prolonged period i just connect the mains from my old mover lead with RCD plug under my bonnet and walk away... Simples...
I plan to do the same with the TT Cab for winter storage too...
Craig Thumbs Up 06 SUPERCHARGED VSE
2012 Facelift
Overfinch Conversion
22" Overfinch Alloy's & GAP Lowering Module
Jet & Ivory Interior with RE & Hybrid TV + LR iPod Kit
BRC LPG
Post #107622 16th Feb 2012 12:22pm
mrblonde
All
I fitted my new battery on Thursday evening, not used the car til this morning (Monday) and when I checked the flashing CTEK indicator light it was red (indicating charge required), surely this cant be right? Or can it?
Used the car for an hour, 20 minutes drive, ticking over for 20 mins then 20 mins back home, parked up, checked the light again and it was flashing amber/yellow (indicating charge recommended), does this sound right guys?
If yes, then I have a pretty serious drain, given its a brand new Bosch 110Ah, 920cca battery Big Cry
Please help Bow down
Post #108239 20th Feb 2012 3:19pm
How exactly have you connected the Ctek to the battery?
Where is the Ctek located?
Post #108243 20th Feb 2012 3:27pm
mrblonde
CTEK is the indicator light thingy, and a charging adapter on the end of it, its connected to the car battery itself with eyelets to the terminals, and coiled up in the battery compartment (theres about 10 inches of cable)
Post #108244 20th Feb 2012 3:35pm
mrblonde
would it make a difference where it is nicedayforit? Just wondering as I'm useless with anything electrical Embarassed
Post #108245 20th Feb 2012 3:36pm
Page 2 of 4 <1234>
